crossover/sway bar ?
Discussion in 'The Garage' started by seattle73k5, Jul 7, 2005.
  1. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    Can you run crossover with a sway bar? It seems to me that if I am looking at it right the crossover would run into the sway bar during flex is this right or am I looking at things the wrong way?
  2. dremu
    Feb 27, 2000
    15,951
    440
    East of San Francisco
    Sway bar? Sway bar? What's that? :haha:
    Seriously, I think any rig that ends up with crossover has ... well, crossed over into the territory of not needing a sway bar.
    Heck, I've got an otherwise normal *10-bolt* up front and no sway bar and she's almost streetable :haha: it's prolly those damn Rancho springs, stiffer than 1/2" steel plate, I swear, but hey, they were free :deal:
    -- A
  3. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Yeah the sway bar goes bye bye. I got rid of mine 3 years ago when I went crossover. My rig is totally streetable. I even pull my 27' trailer no problem. Cornering is still great as well.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeah, the swaybar gets in the way on the passenger side.
    Unless you run really stiff springs you need the swaybar in order not to be uncomfortable to drive. My BDS springs will institute so much body roll that it's scary without the swaybar.
    My wheeling rig has no swaybar and has crossover. It just rolls over until it hits the bumpstops.
  5. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    So your saying that when I put my TC or BDS springs in and xover steer, I will have rendered my rig useless for a DD?
  6. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I wouldn't say "useless"... you just have to relearn how to drive it... taking it easy on corners and such.
    j
  7. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Well, as an experiment, I took the sway off of my stock Blazer and went for a test ride. The ride on choppy roads seemed to improve slightly, and on the twisty roads, the truck still tracked the same just with a little more body roll. Deffinately not uncomfortable. Now where it seems to make the biggest difference is very quick turns such as an evasive manuver (dodging something in the road and such.) This really needs to be thought about when losing the sway bar. When jerking the wheel the body is very tippy and I would assume would be worse the taller the rig. :doah: One more thing to think about. That's all I need.
  8. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,268
    159
    Wisconsin
    I have TC springs, crossover, and no sway bar, and I could drive my truck every day no problem if I didn't mind paying for gas and tires. Sometimes I do drive it a lot, it drives fine I think. A little body roll on the sharp turns but it's no problem really.
  9. seschev3
    Jan 19, 2005
    308
    clayton, ca
    You can still use your sway bar, depending on lift, as long as you do not plan on hopping curbs and such, and use sway bar disconnects. I used mine for a month after my crossover was installed with an 8" lift. When I got to the trail, I would disconnect and pull the 4 bolts out and throw it in the back. But it is a big pain, so I rode home without it and never put it back on. I drive my rig everywhere with no concerns at all for 3 years now. Front end tracking is more of a concern for me.
