Crossover - Tie Rod
Discussion in 'The Garage' started by AZ79K5Project, Feb 18, 2007.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I am in the process of finishing my crossover. My knuckles are off a 76 which has the top down tie rod mounting. The stock one has a drop style tie rod. My stock 87 tie rod has about 1/8 inch clearance b/w the tie rod and springs.
    Anyone running a HD style tie rod on a top down knuckle?
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Man i didnt understand that, Could you maybe try to clarify?
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am but I am running 0-rates too. I did notice that clearance would be very little without zero-rates. With 0-rates I needed a spacer under my crossover arm to keep the draglink off the top of the springs. I am not sure if they make the dropped style aftermarket TRE's. I asked this question before though and people are running the same setup as you.
    Here is a pic of mine.
  4. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    I ended up doing highsteer for that very reason... couldn't get the tierod (aftermarket) to go down into the knuckles.
    -- A
  5. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I put the joints into the knuckles, then threaded my (aftermarket) tie-rod onto the two joints. Only way they went together. I went hi-steer the first time I had to replace a joint.
  6. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    That's the way I did mine on Saturday. I'm just thinking about a trail replacement issue.
  7. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Sure - the top down mounting for the stock setup has a drop type tie rod. Napa's part number: MRCDS841
    Normal TRE's don't have the "bend" to get the tie rod away from the springs. It makes changing them a PITA.
    Here's a link with a picture of what I'm asking/talking about: Click - pic is about halfway down
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    looking at that pic it seams like someone could use that same draglink but with a heim at the knuckle and no zero-rates, and do one of these numbers...for a quick and easy cross over install...
  9. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I dont like the idea of highsteer on a 44 though. It puts alot more strees on alot less area... The balljoints are small already, and now its just incresing forces on them...
  10. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    I've read a few posts where high steer has caused or been a factor in the sheering of the bolts and other breakage.
