Crossover tierod question
Discussion in 'The Garage' started by Hossbaby50, Sep 11, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I bought a HD tierod for my truck awhile back. I am now starting the gathering of components for crossover steering. (just purchased knuckles) and I want to know if I can keep using my current tie rod with the crossover.
    The axle is a 10 bolt front. Will my tierod work ok, or will something need to be changed? If so what will I have to do?
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    your tie rod will be unaffected with the crossover /forums/images/graemlins/thumb.gif
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    AFAIK, ur good. On my d60 the tie rod is uneffected by whether or not I have x-over... arent 10 bolts the same way?
    j
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    sweet. That is what I thought, but I couldn't confirm that threw the material I had been threw so far. Thanks
    Harley
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    no problemo. I had 10 bolts at one point... but I never really messed with the steering on it so Im far from a guru. I did setup my own tie rod + x-over + hydro system on my D60 tho, so i got that much figured out. In any case, Im almost positive that no matter what you do with your xover, you should be able to keep your beefy tierod.
    j
