Crossover w/no swaybar, truck now bump steers way 2much
Discussion in 'OffRoad Design' started by orlandoc, Oct 15, 2003.
  1. orlandoc
    orlandoc Registered Member
    Sep 23, 2002
    26
    Puerto Rico
    I got my ORD D60 crossover steering kit and everything worked just as designed, thank you ORD. Truck was driving well with no problems but lately it's almost getting out of control during normal city driving and hitting a small bump. Is there a way to correct this problem? alignment maybe? Please advise.
    Orlando /forums/images/graemlins/burb.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    It sounds to me like the infamous DW (Death Wobble). I have started to experience this myself, when I hit a small bump in the road the whole front of the truck starts to shake from side to side for a second or two. I replaced everything on the D60 when I rebuilt the front axle but I believe that either the king pin bushings or the springs are now shot so I ordered a new pair from ORD recently and once I get the garage cleaned up I am going to replace them and see what that does for me.
  3. orlandoc
    Sep 23, 2002
    26
    Puerto Rico
    Please keep me informed as to how everything works out since I may need to do the same work. I'm experiencing some drivetrain vibration, should I lower the Tcase some to try and correct the problem?
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Since you have a 6" lift I doubt you will be able to get rid of ALL the drivetrain vibration by dropping the T-case or shimming the rear axle, but I am sure you can improve upon it. Usually with anything 6" or more of lift on a short wheelbase vehicle such as a blazer you will need a C/V driveshaft to eliminate ALL vibrations. To correctly get rid of vibrations both U-joint working angles need to be the exact same (so they cancel each other out) and also be between 1/2 to 3 degrees on a typical (2) U-joint driveshaft. This is very hard to accomplish on short wheelbase vehicles, you will usually have to sacrifice one for the other or go with a C/V driveshaft. If you go with a C/V driveshaft then you need to point the pinion about 1 or 2 degrees downward of the driveshaft centerline, (this will allow for axle wrap in the upward motion) so when you are driving the pinion is pointing directly at the T-case.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Hopefully kingpin springs and bushings will solve the DW problem and shimming on the rear axle should take care of the vibes. A sub should be able to run a 6" without a CV, especially if you're willing to drop the t-case.
