Crossover with a front 10 bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Dec 4, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Anyone out there running crossover with a front 10 bolt axle? What kind of setup are you running?
  2. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Yeah, come on, I hate bump steer!!!
  3. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Oh man, how discourging this is...
  4. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I think the thing is...if you are doing the kind of wheeling to NECESSITATE x-over and still have a 10 bolt, your steering woes are going the be the least of your worries. That aside, I would think you could swap the knuckles for the flat-top Dana 44 knuckles (and outers), and do a crossover that way.
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    yep upper and lower ball joint part nu#'s are the same 10 bolt or d44 but i also believe you need the d44 tierod to connect the knuckles i encourge you to make sure before you get into something /forums/images/graemlins/eek.gif
  6. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    Yep, I have one on my '87 10 bolt. I got some flat top knuckles from a '75 Chevy Dana 44, filed the top of the flat top myself and drilled and tapped the knuckle myself and installed a crossover arm from Off Road Design. I took an old tie rod from a mid 80's Chevy Blazer and bent it up to make my drag link and used stock tie rod ends. Total investment was less than $100.00.
  7. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    You got a crossover PITMAN arm from ORD? Does it just have the teeth in a different spot so you can rotate the pitman 45 degrees?
  8. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Any companies out there that would make a crossover draglink for this type of application?
  9. WhiteWhomper
    Sep 23, 2000
    227
    I got both pieces from ORD. the steering arm that attaches to the passenger knuckle and the pitman arm that attaches to a 2 wheel drive steering box. (Which is a modified jeep arm)
  10. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    ORD, Rockstomper, Shakerbuilt, Avalanche, etc.
