crossover
Discussion in 'OffRoad Design' started by 86chevybanshee, Jun 8, 2005.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    im building an s10 with a d60 up front and i want to put hysteer/crossover on it. when i order it do you ask for measurements for the draglink?, im gona be running it full width so the tie rod would be the same length.
    also would the pitman arm you inlcude in the kit fit a stock s10 steering box?
    thanks
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Best thing to do is get everything but the draglink, mount it all up and measure for the draglink. That's pretty standard with stuff we can't get a good guesstimate on.
    The pitman arm should fit your box just fine. If you have drop problems (some custom appplications need less drop) we can work on sorting that out too.
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    cool, ill give ya a call when im ready to order
