Crower cams, any good?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Dec 11, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Has anybody used Crower Cams and if so how did they work. /forums/images/graemlins/ears.gif
  2. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I have great luck with Crower cams. And roller rockers
    I would use them agine. Hope this helps.
    Bo
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    not much of an engine guru, but got a buddy that is, and is into drag racing etc... he swears by crowers for most applications.
    I got a couple picked out I'm trying to decide between for my TPI engine I'm throwing in my hotrod. /forums/images/graemlins/thumb.gif
  4. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I was very happy with mine, but aren't there only a couple of camshaft manufacturers that distribute to all the mainstream companies like Erson, Crower, Comp etc. /forums/images/graemlins/confused.gif
  5. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    this won't answer your question, but i bought a crower baja beast cam a few years ago at a shop going out of business, still have it and have wondered if it is any good?
  6. bajaviking
    Apr 10, 2002
    752
    Baja
    Recently I put in new lifters and my valve train is in good shape, can I put in a mild cam and leave everything as it is or do I need to make other modifications to make it work. I am not building a drag racer, just looking for a little extra grunt. /forums/images/graemlins/thumb.gif
  7. dyeager535
    26,982
    191
    If you are just dealing with a stock cam, and heads, you can probably bump it up a bit without hassle. Too much lift and you'll have valvespring problems of course, but there are a bunch of variables. If everything in the engine is stock, sure.
    Just make sure that what you are contemplating putting in the truck may very well be smaller than whats in there now if a PO changed it. Also, a "smaller" cam in most cases makes more power down low. Just up to you where you want the power, and how much.
