Cruise Control 1993
Discussion in '1992-Present Chevy & GMC models' started by pauly383, Jan 31, 2007.
  1. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am searching out those who had fixed their early 90's cruise control . Its the ONLY thing that does not work on my tow rig . All wires are connected , thats all I know so far .
    Learn me , all I have ever done before is remove them , not make them work :thumb:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I do see 4 wires on the cruise/wipers stalk , they are external and go into the column.
    I have blue , yellow , green , and brown . I am thinking I need a diagram for this system and cut these off and touch the right ones to see if the switch is bad .
    Off a searching I go , please anyone post up advice :thumb:
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    it's been awhile, but I think those are still vacuum, make sure the diaphram holds vacuum, and make sure the line going to it is good. and let me know if you need anything else, I can print out a wiring diagram at work if you need one.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    No vacuum , there is a box with the computer and a stepper motor . Cable actually comes out of ther box and snakes it way to the throttle body .
    I wish it was vacuum style . Then I wouldn't want to fix it , I would remove it :thumb:
  5. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    ok, can't picture that one in my head, but anyway, let me know if you want a diagram.
  6. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
  7. 84zz4ss
    Dec 28, 2004
    1,342
    Pensacola FL
    Maybe that will help.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It does . Thank You :bow:
    Happen to know which colors are what ? If not I can look for 12 volts and figure the rest .
    And for some reason , I have no fuse marked cruise , no spot for it either . :thinking: Is it on the firewall breakout box where all the spade terminlas for accessories are ?
  9. 84zz4ss
    Dec 28, 2004
    1,342
    Pensacola FL
    Fuse may be labeled guages in the dash panel
    AT SWITCH
    dk blue- reset accell switch engaged
    dk green- set coast switch engaged
    gray- cruise switch on
    pink/black- ignition on
    AT MODULE
    same as above with
    blk/wht- ground
    brn- brake switch-clutch switch
    wht- pcm input
    brn/wht- vss
  10. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    The switch itself is usually the first thing to go on these trucks.
