cruise control help???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bklynlifted, Feb 6, 2002.
  1. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    ive been told there is a fuse that controls the cruise cntrol question is where is it???? i have an 88 full size jimmy its not in the fuse panel???stumped. ps also checked the vacumme tank no leaks there??? no play in the turn signal?? nothing happens when i try to activate the system???? need help thanks.
  2. dyeager535
    26,982
    191
    The cruise might be on a "convenience center" located somewhere above the gas pedal. Cars ended up with cruise on that circuit I believe.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. bklynlifted
    Feb 4, 2002
    261
    thanks for the reply you mean the fuse ??? might be above the gas pedal??
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I ripped out the convenience center from an '87 yesterday, all that was on it was the Hazzard flasher, horn relay, and buzzer. Start by checking all the fuses in the fuse panel, I think my CC was powered by a fuse labeled simply "20" (for the amperage). Mine also went into the front of the fuse block, the CC hot wire is pink/black.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. bklynlifted
    Feb 4, 2002
    261
    define convience center???
  6. Can Can
    15,555
    152
    Cochrane, Alberta, Canada
    The cruise control is tied into the "Ignition" fuse on my 84. If the fuse boxes are the same I can email you a diagram of it.
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  7. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Id bet you $20.00 that you need a new "multi-function" switch. (the turn signal lever) that's what fixed mine, and so many others.... just do it..... it'll fix it !!!!
    1990 K5 4" lift, 33's, 14FF Detroit locker, D44 w/ posi, 4.10's Raptor Tranny and Velvet Rides....
  8. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    My cruise only works with the tilt all the way down &amp; only sometimes please help, Chris
  9. dyeager535
    26,982
    191
    Don't worry about the convenience center, at least in the '86, it has nothing to do with Cruise. Cruise used a box above the pedal assembly to control it. In the cruise control diagrams, I only saw a 2 amp fuse, but the diagram was kind of nonsensival. I'm sure the fuse was on the fuse panel, but they didn't mention it, and in the troubleshooting section (this is the GM manual) "check fuse" is not one of the steps.
    Dorian
