Cruise control help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Oct 20, 2000.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    My CC in my '84 hasent worked in 2 years. everything seems to be in place, no toasted wires or vac leaks, etc. The damn thing just dosent do anything. If someone has a troubleshoot or service manual info i'd appreciate it. Cav444@hotmail.com Thanks
    Luke
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Do you have a FAX machine available? I've got info for an 83 and it should be close.
  3. CAPTAINK5-CT
    CAPTAINK5-CT 1/2 ton status
    Sep 10, 2000
    124
    CT, USA
    My set button is missing. Need to change the unit that mounts on the colum. Any pointers on how big a job this is?
  4. Cavalry
    Oct 1, 2000
    978
    Smitty, That would be great. But I can't get into the office till mon to get the #. How many pages are we talking here? Thanks again
  5. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Cavalry,
    Total of 16 pages. Get the number and I'll send it off. I can copy and mail it to you if you'd rather go that way too.
    Smitty
  6. Cavalry
    Oct 1, 2000
    978
    Smitty,
    If its not too much of a hassle could you mail it. That way its all saved on disc. I can just about plan on loosing page 11 which has all the info i will need lol. Thanks Luke
  7. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    No problem. I'll send it out Monday. Send me your address offline.
    Smitty
  8. Cavalry
    Oct 1, 2000
    978
    Smitty,
    I'd love to send you my addy. but yours is not listed in your bio. I might be a little confused here (too much paint fumes or something) did you want to send this email or USPS? Luke
  9. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I don't have a scanner so I'll send it USPS. It's cheap to send it second day express. My email is whsmith@saber.net. I'll check out my info and update it today. (Didn't think I'd get as addicted to this list as I am.)
    Smitty
  10. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I think the typical problem with the CC not working is the wire in the steering column breaking. Look under your steering column for a black wire, kind of wide and flat and trace it to the plug. Unplug it and use a test light to see if the switches on the signal wand work. I can't remember which terminals are which but one should be the ground and the other three should show a light when the switch is turned on, set cruise, and resume are pressed. The individual wires are really small so they break eventually. I'm not sure how hard it is to replace the wand but since mine doesn't work either, I'll find out someday.
    Joe
    RIT Mini-Baja http://www.rit.edu/~bajawww
    Team Mudnuts http://www.mudnuts.org
  11. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    Also check the plug itself, like jcg says a wire pinched in the steering column is often the problem, and if it' s the same plug as my '87 its got two flat plastic prongs( or some kinda material) with foil strips on them. When the wire in my column got pinched, it melted the foil off the plug, I actually heard the little pop noise it made when I shifted into reverse and bingo no cruise from then on.
    Denis -MIDCAN k5 " DIG A HOLE!!!"
  12. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    The copies of the cc section are on the way. Hope they help.
    Smitty
