CRUISE CONTROL INSTALL
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big d, Dec 29, 2001.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    what does this entail to remove cruise control from a donor vehicle and install it again in a vehicle previously without it. is this practical and would it be better to purchase an after market kit. im really looking for original, working equipment. anyone with comments/advice or a system to sell please let me know or help. all is appreciated. thanks ahead of time and happy new year !
    darrenolander
    galva,il.
    1979chevycheyenneblazer
    350/350
    gettin'down on all fours, 4 a'little
    x4 play !
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Thats funny, I'm in the process of ripping mine out. I think mine is different from a '79 though, I have electronic cruise. I think '79 still used manual (2 piece speedo cable), but not sure. Anyway I'd think it would certainly be feasable with factory parts.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if you are going to the bother of putting one in, you might want to look into an aftermarket unit that doesn't rely on engine vacuum to operate the throttle. the older units I had wouldn't maintain speed on hills because the engine vacuum drops, my '95 which doesn't use vacuum works great uphill or down. the newer non-vacuum gm systems use inputs from the ecm to operate so it would be a difficult swap. just something you may want to consider.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  4. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Are you sure it doesn't use vacuum? I just finished pulling mine out ('83 truck), and it seemed essentially the same as the '88 diagram I was using. There is a module behind the dash, to the R of the steering column, the VSS (optical sensor on the speedo till '89, driven off the tranny/t-case from '90+), VSS buffer thingy, switch, etc, but all the electronics controlled a vaccuum motor under the hood. I've never really looked at one newer than '89, though.
    Pete
  5. 95 Silverado
    Nov 9, 2001
    467
    Central PA
    no vacuum, I went and popped the hood to make sure. square box, bolted to the firewall, cable runs to throttle, no vacuum lines, just wires
