cruise control
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, Apr 13, 2001.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    my cruise control doesn't seem to be working. i haven't even looked under the hood yet, are there any obvious things i should check? any standard gremlins in the system?
    it's on an 89, btw.
    <font color=purple>delta9blazer</font color=purple>
  2. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    The obvious thing would be to check for a blown fuse, and then look for vacuum leaks under the hood. After that it gets a little tougher to find the problem. There was a recent thread on cruise control that may be helpful. I couldn't get a link to work so I brought it back to the top. It's called "What could cause this?" Good Luck
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i had the linkage break on mine...that actuatior was workin fine but just not doin anything because the place where it hooks to the actuatior had worn through and broke off....so i had to replace the actuatior...and what a bitch that was....its hard as hell to get to the little screws that hold that thing on....if you can live without cruse...just wait till you have to pull the motor then change it then...if that is the problem
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Someone just posted this...
    Anyone know why my cruise control will only work when the windshield wipers are on?
    They got this response....
    The lever or switch was bad. Bought it from the dealer 5 years ago? ($75 bucks?) CHA CHING! Get an after market or one from Cheyenne, LMC or other. Open door push in on lever towards column(spring loaded), rotate 1/4 turn to left, comes straight out. Disconnect harness , reattach and insert truning to the right. Don't think there's a need to disconnect battery.
    Mine stopped working too last summer but since I rarely use it I didn't really care. I'm gonna check into this as well as the other stuff....but I thought I would share this with you in case this would be of some help! [​IMG]
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  5. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I would first check to make sure all the components are there that belong to the system. all cruze control systems that I have worked on didn't work b/c they didnt have all the peices.
    Insurred by Smith & Wesson
  6. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    Sometimes the wiring gets pinched in the steering column, causing a short. On mine I found a plug at the bottom of the column that had fried because of the short. It's a flat 2 prong plug about an inch wide, the prongs are actually made of a composite material with thin strips of foil stuck to them, the foil on mine was toast. I bought an new control arm from GM, installed it and it worked. Keep in mind though that someone tried to steal my truckby busting open my steering column, and when it was repaired at the shop, that's probably when the wiring was put in harms way.
    Denis
  7. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Hey Steph,
    Check out the rest of that thread... I had forgotten sumpin!
    Good luck,
    BBN
  8. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Change out the turn signal lever. I have found that the wires break, causing the malfunction. I have taken it apart but you have to ruin it to do that unless you do it right. If you can get a small screwdriver under the slide switch you can snap off the last piece on the lever, it surrounds the button for setting cruise. Once this is off you can slide the rest out. I replaced the wires and put new shrink wrap on the wires and spliced the connector back on and replaced the lever back on the collar. Otherwise, just hit the junk yard and get another one. I got a new one for 5.00......
