cruise control...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kelboski, Aug 26, 2000.
  1. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    quit working on my K5....is there a fuse for it?.....what could be the problem?...
    Kelboski
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Yes there is a fuse. The easiest way to check the fuses is to take a test light and ground the clip. Then turn your ignition on and test both sides of the fuses. If it is a blade type fuse, there is a little spot on each side of the top ogf the fuse. If the fuse is blown, then only one side of the fuse will show voltage. It is easier to do it this way, then to pull all the fuses and visually check them. Also a visual check can sometimes not work. Hope this helps.
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    The wires in the lever or column may have broken. That's what happened to my old car and my Jimmy. In my old car I just wired up some buttons on the dash (it's a POS anyway) but I'm going to get a new lever for the truck one of these days. Taking apart a steering column is one of my least favorite things to do.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  4. Kelboski
    306
    Mcdonough,Ga
    lol jcg...POS thing.........thanks for the replys fellows...i'll check it tommorow..Kelboski
  5. Kelboski
    306
    Mcdonough,Ga
    my god...Dblazer....what's it like having 5:13's for gears?....
  6. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    Extremely cool. It isnt as bad as everyone thinks. I have the 700r4 so the overdrive helps. I cant drive 70 mph. But i diont speed anyway. I usually cruise in the slow lane. But when I put the Atlass in low and the blazer is in first, man does it crawl. up and over the rocks. It is an awesome feeling when i finbesse my way over stuff, just a crawl. My only regret is that I didnt do the 4.1 in the atlass, as it is I went with the 3.8 to 1. See ya, hey buy the way, can you see my pic on the left there???? It was working on my screen for a while then it quit. I dont understand
  7. Kelboski
    306
    Mcdonough,Ga
    i don't see it...?
  8. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    Yah, it seems to work sometimes and sometimes not. Hell I dont know, I am computer idiot. Usually my wife helps me do that knid of stuff, but she had her "wisdom" teeth pulled today.[​IMG] So shes on pain killers and isnt so "wise" anymore[​IMG]
  9. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    But the bat worked?????
  10. Kelboski
    306
    Mcdonough,Ga
    it worked..the bat
  11. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    On my car, the CC quit working and the problem turned out to be a crack in the vacuum line. I don't know if yours works on vacuum, but if it does, check or replace the vacuum line.
    '89 K5 Silverado 4" lift w/BFG 33's
