Cruise/wiper switch - where does it plug in?
Discussion in 'The Garage' started by PonchoCatalina, Jul 28, 2005.
  1. PonchoCatalina
    PonchoCatalina Registered Member
    Feb 8, 2005
    18
    College Station, Texas
    The cruise control / intermittent wiper stalk on my '86 Suburban (6.2) was not working correctly, so I ordered a replacement. It arrived today and after ripping open the package, I raced out to install it. I removed the painted metal panel and the plastic panel under the steering wheel, but can't seem to see where the existing plug is. Any tips? Thanks!
    - Ian
  2. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    it should be about 6" from the firewall on the top of the steering collum.
    it has a slot that slides over a small tab there but, if its not there look for a black connector with 4 wires the wire colors are 1-light gray with a black stripe 1-dark gery 1-light green 1-blue the conector its usualy shaped like the state of utah hope this helps
    balzer
  3. PonchoCatalina
    Feb 8, 2005
    18
    I found it - it was hiding behind the under-dash ductwork. Thanks for the help.
