Cruise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr. Jimmy, Sep 3, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    Cruise is not working on my 89 Jimmy,What is the most likely cause, or where do I start looking?
    Thanks, Keith
  2. McD Blzr
    McD Blzr Registered Member
    Apr 23, 2002
    16
    San Jose, CA
    You're going to laugh at this one, but I fixed mine ('89) by simply adjusting the brake light switch. My mechanic suggested I try this before I actually brought it in. It was not aligned properly with the pedal, has worked great ever since.
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    The cruise thing that sits up by the carb (or TBI whatever it may be) has a diaphram on it... could be punctured.
  4. dyeager535
    26,979
  5. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    Had to replace the turn signal lever on mine. The one of cruise control wires broke inside its insulation right where it comes out of the stalk from all the years of flexing. It started by turning off any time I used the blinker to change lanes, then eventually quit working altogether. Used a wiring diagram and a test light to track down the electrical problem.
