Crunched up fender with 6" lift and 33's!
Discussion in 'The Garage' started by TX Mudder, Mar 22, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Crunched up fender with 6\" lift and 33\'s!
    My 33's look pretty small under a 6" lift, so I thought there would be no way they would make contact.
    I put two new fenders on a few weeks ago and just this past weekend took the truck out.
    Somehow i managed to to crunch up the driver's side front fender rear opening. The tire looks fine.
    I wonder what I'll be able to do with 35's.
    And I didn't even disconnect the sway bar or anything...
    -- Mike
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Crunched up fender with 6\" lift and 33\'s!
    For some reason that I can't explain, the driver side fender seems to ALWAYS get hit more than the passenger side.
    My '85 K30 with 4" and 35" hit on the rear part of the driver side front fender when it gets flexed out. If I turn into a steep driveway or ditch, the tire makes contact.
    No clue what to tell you, but 33" should not be hitting with 6" lift. /forums/images/icons/frown.gif
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    thats weird... when i tweaked my fends with my 35s... i was disconnected and only had 4" of lift. They didnt even really rub that hard, just caught an edge of a tire lug on the bottom of a fender well lip and pulled it down. Seems freaky that with 6" and 33s that you rubbed really hard with the sway bar connected. You have some super loosey-goosey front springs or something?
    J
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I had a 4" susp. and 3" body lift and 33s on my K5 and I could rub the bottom rear corners of both front fenders once in a while.I had no sway bar and realy soft front springs.I never thought it would hit either.
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You'd think that 33's and 6" would clear, but I managed to nail mine. It was on the drivers side too.... pissed me off because I wasn't even doing much other then dirt mounds behind my church where we go all the time!! ARGH!! /forums/images/icons/smile.gif
  6. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    No weird suspension stuff - 6" ProComp springs, ORD bushings.
    Oh, and have the longer front shackles from ORD so another 3/4" lift or so.
    I was driving the truck pretty hard (for me.) It's the first time out since I put in the new engine so I wanted to see if it would break.
    Didn't.
    -- Mike
  7. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    I would have to agree with you on that. My drivers side on my 84 rubs everytime the thing moves but the passengers side never touches the tire. I dont know???
  8. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Why don't you just trim the fenders a little bit?
  9. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Here are some pics of mine (Memphismadman) flexed out. This is basiclly a new lift-First time it's been stretched. It's a 6" Superlift and 33s with the ORD disconnects. I all ready had mild trimming but it still bit the metal. Note: ftn96 is the white k5 under my pics (Nashvillek5).
    <a target="_blank" href=http://www.tennesseeoffroad.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&amp;f=31&amp;t=000001>http://www.tennesseeoffroad.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&amp;f=31&amp;t=000001</a>
  10. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I have the "i have new fenders and want them to stay pretty' syndrome.
    I already got one dent from a tree though. I'm starting to get over it slowly.
    I just hate the thought of trimming back perfectly good sheetmetal. If they were rusted out like the old ones, then yeah...
    -- Mike
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I bought new fenders a couple of years ago and trimmed them back as soon as they were bolted on. I had seen what happened to untrimmed fenders with the old rusty ones, but didn't want more lift.
    I got over it.../forums/images/icons/smile.gif
    Rene
  12. RobbieOH
    RobbieOH Registered Member
    Feb 15, 2002
    79
    Shoreline Washington 98133
    The drivers side might rub more than the passenger side because theres more weight over that side (you the driver) bringing the fender and wheel together easier. Just a thought I dunno.
  13. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    The drivers side also has the mastercylinder, wiper motor, fuse pane, pedals, steering column, guages, radio, windshield washer reservoir, and as stated driver so it's no wonder it's usually the first side to hit. That and the older the vehicle springs are, the more worn they are on the driver's side due the weight on that side. Maybe I am just talking out my butt here, but it does make sense. Also I'm wondering if the axle offset has anything to due with it. All GM 4x4 (solid axles) I have seen one front tire sticks out more than the other, I don't remember which side, but that may also compound the problem. My 4" with 33's (measured more like 31" when worn) and they hit pulling into driveways while turning. True tire sizing and wheel offsets can compound this problem, as the tires probably won't hit if the wheels are pointed straight forward, but might hit without too much compression if they are turned to one side (even slightly, they don't necessarily needs to be close to steering lock to move closer to the sheetmetal). Hate to hear they are rubbing, but it sounds like you will have to do a little trimming or live with some "altered" sheetmetal, and possible chunks missing from the tire (which happened before I went higher). With new springs (the old 4" ones were severely beat and sagging) and tires (35's that measure closer to 34's). I don't have any problems.
  14. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    DAMN that sucks. I'm about to be running 4" and 38s too.
  15. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    5" of suspension lift, 1" of ORD body lift... and 39.5s for moab baby... hello Mr. Sawzall... /forums/images/icons/laugh.gif
    J
  16. JustCuz
    JustCuz Registered Member
    Mar 23, 2002
    76
    Michigan
    Man I have 12" of lift and 44's and all 4 of my tires hit. /forums/images/icons/smile.gif
    Time for some cut out flares.
    -JustCuz
  17. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    bah, don't need no stinkin flares... just CUT!! /forums/images/icons/tongue.gif
    J
