Crunching Noise
Discussion in 'The Garage' started by 78Suburban, Jul 14, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    When I crank my burban it will occasionally make a crunching noise like the flywheel and starter are having a fight. what is causing this and is it harmful (sure sounds like it). can I fix the problem
  2. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    Hello
    Hay man you need to get under your ride and check things out . you will prob. have to change the starter. but dont wait to long or it will cause perm damage to the flywheel . If it has'nt already :eek1:
  3. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    Mine did that not long ago and crunched the transmission pump on the 700R4.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    What problems do I need to look for? How much would I new starter cost? It only does it every now and then, it usually turns right over and fires right up.
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I'm really scared. Is the suburban I purchased a damaged piece of junk? Please give me some advise yall. What do I do about the slipping when I try to crank it?
  6. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    sorry I keep bumping this up, but I am really concerned. Is this a common problem? Do I need to replace the flywheel and/or starter. please give me some help and advise, I don't want to srew up my tranny or anything on my burban.
    Please Help me
    Thanks very much :D :bow:
  7. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    Mine was a rare condition.... the bolts on the flywheel backed out. It took out the flywheel, starter, and tranny. Good thing I was about to replace the engine. It turned out I replaced the tranny while I was at it.
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    wonderful.
    I might blow my suburban up with dynamite for kicks & giggles
  9. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    The common problem is that it will eat up the teeth on the flywheel if your starter doesn't line up correctly. Then you're in for replacing the flywheel and the starter. Its definitely worth your time to get under it and look around.
  10. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    look around for what? take the starter off and look at its teeth? Could my flywheel be warped in some place? I imagine replacing the flywheel would be a PIA.
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I almost feel like I am talking to myself, but maybe a few people will respond. After reading a bunch of previous threads, I have decided to try a starter shim kit. I feel like this is almost grasping around in the dark, but maybe I will get lucky and solve the problem........ it this a good idea......... anybody???
  12. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    proll mix of blazer fest and friday :D i have no life so my guess is ...
    see if bolts are loose
    take starter off and look at the teeth - starter and fly.
    check to make shure the starter isnt binding or not releasing after the thing starts.
    dust cover clearence.
    if u still havent found anything put it back to gether (use some locktite) and see if it does it again. sometime she just wants u to kiss the boboo and it is all better(mine does anyway).
    if it does it again well go in to more complicated stuff :wink1:
    ive never had to shim mien-its a ford thing id try this stff 1st then see. ull be able to tell if that is the prob after u take it apart- or take a pic and we will tell u :D
    oh and what are ure specs(engine,tranny,year,ect...)
  13. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    350,th300, 1978 K20 burban. thanks, I will try to take it off and look at it. do I use blue or red locktie to put it back on?
  14. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Crawl under there and make sure the starter is bolted down tight. If it is loose, it sounds like this until the bolts break off and the starter falls down, arcs out on the axle and fries your electrical system. Sometimes the first thing to do is look at the problem and see if anything is obviously wrong. :doah:
  15. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    crawled under there. there starter is as snug as a bug. Now what? will the 2 bolts remove it? How do I see the flywheel?
  16. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
  17. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Take off your flywheel cover (dust cover) and there the flywheel appear's! Then you can check it all out.
  18. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Rusty, thanks for the link. Chaddy, how do I get the flywheel dust cover off and what does it look like? is it the black cover thing that is held onto my starter with a large phillips head screw????????? sorry for my ignorance, but I've never fooled with a starter.
  19. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    S'io credesse che mia risposta fosse
    A persona che mai tornasse al mondo,
    Questa fiamma staria senza piu scosse.
    Ma perciocche giammai di questo fondo
    Non torno vivo alcun, s'i'odo il vero,
    Senza tema d'infamia ti rispondo.
    :eek1:
  20. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Nao e necessario chorar rapaz - so espera um pouco, poucas pessoas estao aqui nos fims de semana.
