crush sleeve on a D60?
Discussion in 'The Garage' started by beater74, Oct 8, 2005.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    who come my D60 install kit comes with a crush sleeve? i have torn down my d60 and as far as i can tell it didn't have a crush sleeve on it.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Some D60 pinions use a crush sleeve, and some use shims. If your gears did not have a crush sleeve originally, you do not need it. Even it you do have the type of pinion that is designed for a crush sleeve, a lot of people replace it with a spacer and shims.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Your 60 has shims to set the pinion preload. When you took it all apart did you notice the little shims around the pinion? Those replace the crush sleeve.
  4. beater74
    May 29, 2001
    1,749
    atlanta
    yeh it's got shims on it. i figured that was it.
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The crush sleeve is for ball joint style axles. I believe most/all of the other parts in the diff are the same so it's easier to add one or two pieces to an existing kit than create another package and part number.
