Crushable?
Discussion in 'The Garage' started by roadnotca, Mar 24, 2006.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Somebody stop me if I'm in danger. Reverse Engr. How about eliminating the problems associated with the crusher by replacing it with a spring? That is if a stiff enough spring can fit. The "spring" would be shim-to-fit like a solid, and compressed height as long or longer than a crushed spacer. I think we've got nothing to lose.
    Aaaahhhh!!! Lunatic!!!!!:haha:
  2. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    you mean replacing the crush sleeve in a 14ff right?. interesting :thinking: . it would have to be a very heavy duty spring I would think.
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I would imagine it would have to be a very very heavy spring. the only thing i could think of is the fatigue life of the spring may not hold the same retention as the crush sleeve would. That and a spring is more of a variable rate setup where once the crush sleeve is crushed thats it, its deigned not to go anywhere. I dont know though, try it and report back. Do you have a particular problem with using a crush sleeve other than its difficult to crush?
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Rob, I'll see you this PM. K5er, the sleeve has crushed beyond set-up so I have "clunk". The axle/truck has 184Km. Oh, and its Corp. 10b. Yes it would have to be super stiff within the available space. There are springs made from flat matl. instead of wire, this would be an appropriate application.
    Edit: they're called "strip form".
    The Burb was used for towing a boat, and from the wiring at the rear, I can't tell if it had trailer brakes or just lights but there must have been some de-cel loading on the crushable. Likely some downhill loading too, the drivetrain code is for high altitude. I'll buy a new sleeve from the dealer on Monday and study that. At a minimum, I'll just replace the original.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i would think a solid shim would be much better. the spring would allow the pinion to walk still, no matter how stiff it was
    btw randys sells solid shims
  6. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Intention or not, the sleeve also acts as a fuse. I think it was conciously designed as adjuster and fuse. I'll bet that with a fixed sleeve, the axle shaft becomes the fuse. On a C-clip axle, you know what happens, three wheels and a grenaded pumpkin.
    Front axles don't have the crusher, and they have fuses at the shaft, U-joint and stub.
    As far as play in the drive train, a quiet drive train is for consumer appeal.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I don't understand what you mean a fuse? The crush sleeve has nothing to do with the strength of the axle. It's simply there to keep the bearings specs properly. What are we talking about here? If we are talking about a crush sleeve in between the pinion bearings then no like mentioned above it would still allow play and the bearings will burn up. A solid shim would be the best idea.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Is the crushable design a lot more work than shimming a solid spacer?
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Yeah I would imagine. I have a standard crush sleeve in mine.
  10. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I'd just keep it a crush sleeve...never seen a problem with them as long as you use a new nut and sleeve every time you take it out and you set it up correctly...
