Crushed Rockwell T221
Discussion in '1936-Present Suburban' started by RoknRollr, Mar 13, 2004.
  1. RoknRollr
    RoknRollr Registered Member
    Apr 2, 2003
    16
    SouthBay, CA
    I've got a 68 burban with factory 4x4 running gear. Is anyone familiar with the Rockwell T221 transercases used in those years?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Just a bit.
    What do you need to know?
  3. RoknRollr
    Apr 2, 2003
    16
    SouthBay, CA
    These things have an idler shaft taking power from the input shaft and delivering it to the front & rear output shafts. My rear idler bearing died damaging the idler shaft - the misalignment ultimately cause the "hering bone" gear on the idler to fail /forums/images/graemlins/doah.gif. I'd like a service manual for it - particularly endplay specs. And if someone knows of a good idler gear and shaft... /forums/images/graemlins/thumb.gif
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I used to have a link on my older computer to a website with exploded views and all kinds of specs on them.
    I lost that one but I think I can do a search and find them again.
    If I find them tonight I will post up a link.
    I don't have any parts, but I will put a friend of mine on it, he might be able to locate something for ya.
    I didn't check were you are at but after I post this I will check and if you are close we probably can find you something.
    /forums/images/graemlins/peace.gif
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    OK CA, so it shouldn't be a problem if we find something.
    i will keep you posted.
    /forums/images/graemlins/waytogo.gif
  6. RoknRollr
    Apr 2, 2003
    16
    SouthBay, CA
    Right! Thanks! There's a guy selling a midship/divorced T221 outa LA, but I don't have the time to drive down there -nor will he ship it /forums/images/graemlins/mad.gif. I have a copy of an assembly/exploded view of the T221 but the numbers are hard to read. I had a bookmark of someone posting a portion of the manual - but now that I need it, I can't find the URL! Once I find it again I'll try posting it on CO-K5.
    I've got a 208 and a 241 to throw in there, but the truck is all original (orig numbers matching 327 w/drum brake wet knuckle dana). My 91 burb is setup for real offroad, so I can keep my 68 original & /forums/images/graemlins/cool.gif!!
  7. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    If you need something from L.A. and the guy wont ship it, I go up to Sac every so often. Should be going in a couple weeks again. If you want to work something out let me know. I can bring it up to you.
    Shoot me a pm if you wanna talk. I'll be going to Lemoore this weekend...but that is still about 2.5 hours from you I believe.....guess thats better than 6 or 7 though.
  8. RoknRollr
    Apr 2, 2003
    16
    SouthBay, CA
    In case anyone is following this thread - I've been working with Brad from TransAction in SoCal. He's a friend of Luke's at Klune-V. He's also got a line on parts. I'll try to doc the rebuild incase anyone's interested. Since the transfercases were used prior to the K5, not a lot of people are using them. Several rebuilders don't even know that Rockwell made anything smaller than the 223.
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'd say do the write-up if you have time and patience. You never know when someone will find it handy! /forums/images/graemlins/thumb.gif
