Crusing Speed RPM
Discussion in 'The Garage' started by CHEVY 4WD, Dec 9, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Whats a safe crusing RPM for long distances in a SBC?
  2. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    well with my 3.73s and 36"s i run about 2200 at 65. but i'm going to 4.56s soon which will put me at about 2800 i think.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Anywhere between 2200-2800 is fine. Even as high as 3000 should be OK. Maximum effeciency, IIRC, is around 2400. Lower than 2200 it might bog a bit when you pass. </font color>
  4. muddysub
    Jun 23, 2001
    10,454
    493
    [/ QUOTE ] it does /forums/images/graemlins/frown.gif
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    my cruiseing speed with my 1:1 ratio in the 465 and the 3.08 gears puts me at about 2K rpm at 55mph, so yea OD does help on those long trips, unless yur pulling a heavy trailer. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I found 2200 to be perfect for me. With my 31's and 4.10 gears (was cheating, I have a 700r4), I cruised about 2200 at 70. Now that I'm getting 36's, I wish I'd gone 4.88.
  7. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I drive my rig 100 miles a day and most is freeway traffic.
    I turn 3K and am doing about 70.
    Been driving that for over a year now.
    lil ol 305 too. but she is starting to poop out.
  8. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    So would it be safe to say that 1600-1700 in OD is bad for my junk? I've have had this coversation with others and haven't used OD since.
  9. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    Whoa, hold on!! You said </font><blockquote><font class="small">In reply to:</font><hr />
    [/ QUOTE ] Are you sure? Cuz I turn 3000 at 70 mph (as per GPS and Autometer) but I'm on 35's. Your bio sez you're on 33's with 4:10's, has that changed? I assumed I had 4:10's in my 77 3/4 ton, but that doesn't seem to make sennse. Did the factory offer 4:56 stock? /forums/images/graemlins/confused.gif I've never had the covers off of it, and now it's freezing outside. Does this seem right to anybody?
  10. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    According to all the calculators that is what I am doing.
    My speedo crapped out on me awhile ago so I just use the tach.
    My tires are actualy 31" tall so at 70 with 4:10's I am turning about 3K
  11. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    I ran my 383 a lot around 3K rpm since with 3.73's my overdrive wasn't much use. I didn't have the best motor longevity, I had cam bearings crap on me and the piston fit isn't that great anymore. This is within about 100K miles over the span of about 7 years and I wasn't exactly gentle with it. I ran some pretty big passes on a regular basis as fast as the truck would go. It is a short rod setup.
    In my 'burb with the 4.56's and 315/75's in OD it runs OK but could still use more power. I figure I'm doing 2250 to 2300 rpm and more wouldn't hurt. 4.88's or 33" tires would do the trick I think, or adding some more power. I have a stock EFI 350 in the 'burb.
