Crusty Old Leaf Spring bushings....
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Greg72, Aug 29, 2001.
  1. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    I have never liked the apparent stiffness of my K5, and I had always blamed it on the lift kit, or stiff shocks. But in the last day or so, I've been poking around underneath my truck and noticed that the leaf spring bushings look like they are dryrotted and in poor shape.
    When these bushings get old....can they cause the suspension to bind up and "feel" stiff? I figured I could maybe pick up a set of the ORD greasable bushings and try that as a fairly "low cost" experiment....
    Also, will the bushings be re-useable if I decide later to swap springs, or do they become a permanent part of the leaf, once they're pressed in?
    -Greg72
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would have to say yes. Along with body mount bushings.
    The spring pack bushings are removable once installed. Your stock one however are most likly seased and will be destroyed upon removal. I had to drill mine out like a honey comb before I was able to remove the original bushing. Also there may be a sleave that needs to be removed before you can insert the ORD ones(same as Energy Supension).
    Hope this helps
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    You can also burn the old ones out.Set them on fire with a torch and let them burn.Wait til they go out and they will push right out fairly easy.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I would say no to the bushings being re-useable...
    With my experience, I installed a new lift kit and bushings a year ago, and recently I broke the front shackle bolt on the frame, and the bolt was completly rusted toghether with the sleeve. I tried everything WD40, liquid wrencho, B.F.Hammer, and a torch. I finally had to drill my bushings out like a honeycomb also.
    I had to get new bushings, a new sleeve, and a new bolt.
    And everything was just installed under a year ago.
    I'd say that from the first time your truck sees the rain or a wash, the bolts will start to rust with the sleeve, and good luck getting them back apart, and getting the bolt out without having to drill out the bushings!
