Cryogenicly treat your axles...not a joke!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGRIG, Sep 19, 2001.
  1. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    I just read the new PHR and they had an article about this....pretty cool[​IMG] stuff man. $2.50 per pound is a little pricey though...maybe new parts.
    They said it can almost double the life of some parts. Sweet! Think... A dana60 or 14 bolt EVEN stronger than they are.....oooohhhyeaaa!
    Chris
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  2. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    They do this to Gun Barrel's for the Military to make them last longer..
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  3. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    someone on another forum says he does it to brake rotors and they last forever.. Ive heard of it done to other stuff with amazing results.. first one that comes to mind is a bic razor that never goes dull.. thats pretty neat stuff
    mike
  4. Grim-Reaper
    7,385
    Atlanta
    Yeah the Supra guy's love that stuff. The do Turbo's, Cranks, cams, Rods, Bearings. Something about the molecules lining up and resisiting micro scopic pits and cracks.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    There's companies you can send your gun barrels to and have this cryo treatment done.
    But it's gotta be done right, or it's a waste of time &amp; money.
    September 11, 2001--"A date which will live in infamy"
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    We have this done to our softball bats [​IMG]. It does help.
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Where did ya get the info on this... I wanna find a place local to me and get some stuff done if I can swing it....
    GOD BLESS AMERICA!!!
    &lt;&gt;&lt; MARK 1:17 &gt;&lt;&gt;
  8. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    PHR???
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Popular Hot Rodding. It's a magazine for motorheads. [​IMG]
  10. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Come on, someone clue us in to what you're talking about.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  11. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    They take your parts and cryogenically freeze them, then thaw then freeze... etc.. etc.. It's supposed to line up the molecules and in return makes your part a lot stronger.
    89 K5 Silverado
  12. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    We Cryo many of the parts on our Class 8 race truck (sorry it's a Ford) and have a sponsorship with Cryogenic Science Works in the San Diego area (760) 532-3077. If you want to use them tell Roger that Ramsey sent you. What they do is freeze the parts in a Nitrogen chamber for 24 hours or so and then bring them back to normal temp. slowly. The idea is that as compounds cool they contract forcing the molecules into alignment and relieving microscopic voids and some impurities. It is a hardening process. We have done everything from engine blocks, cranks, pistons to axles, R&amp;Ps, Spools and suspension components, springs, four link parts... I did the Pads and Rotors on my 90 Blazer, you know how fast they can burn up brakes, and so far they have created less brake dust and seem to be lasting longer. We had custom billet rotors made for the race truck before the Baja 2000 and they were Cryo'ed and showed no wear after 2000 race miles. In the past we couldn't get a set of cast rotors to last more than 1000 miles. Rotors wear faster than the pads by the way, with or CNC 6 piston calipers. I used to compete in Bench Rest Shooting and we found that Cryo'ing barrels and actions not only resulted in better barrel life but better accuracy as everything heated up it was more stable.
    By the way we ended up third in the 2000 after leading most of it, some crossthreaded lug nuts caused the rear hub to break apart. Check out the truck at: <a target="_blank" href=http://www.race-dezert.com/index1.html>http://www.race-dezert.com/index1.html</a>
    Ramsey
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    From what I understand, part of the cryo treatment is completing heat treating processes that were somehow not finished. You can get steel structures that don't transform to what they're supposed to be after a quench operation and the freezing forces them to convert to what you were after in the first place. This indicates to me that the gains from cryo treatment depend quite a bit on the material and how it's processed. There's probably more to it than this one aspect though.
    I watched Sam Patton break a cryo'd stub at TTC and figured the money was wasted on a 30 spline stub, you might as well go to a 35 spline and work from there. Cryo treatment is probably down a ways on the list of ways to make something stronger.
    1st, make it bigger
    2nd, use better material
    3rd improve material
    Obviously these 3 get shuffled around a lot depending on circumstances, but for axleshafts which is what we're mostly concerned with, I think the order works.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
