CS 130 Alternater wiring
Discussion in 'The Garage' started by miniwally, Sep 28, 2004.
  1. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    The CS 130 Alternaters have 4 conection spades and the battery charge lug. The Four spades at the plug in are labeled as follows
    S
    F
    L
    P
    S is for Constant Power
    F is for ??????
    L is for switched power
    P is for ??????
    The Sub. that donated it's motor and some wiring to the buggy had a Alternator plug that only used two of these spades adn the Bat. lug of course.
    Problem is the STOCK plug that came on the sub for the Alt. is hooking up to the F spade and the L spade.
    When running the F spade shows Alt. charge voltage. The L spade is the one that I have my Switched power connected to.
    This seems to work out Ok.
    My question is
    What is the F Spade for, also what is the P spade for ???? And second Do I have to show this Alt. Constant Power on the S terminal?
    I have Searched as long as my patience lasted.
    Thanks for your.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Hope this helps
    The "P" terminal is connected to the stator, and may be connected externally to a tachometer or other device. (think diesel)
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Field?
    I don't know, just guessing...
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Here you go. /forums/images/graemlins/thumb.gif
  5. miniwally
    Aug 11, 2003
    3,065
    Colorado
    The Nova Source deal doesn't anwser my question. It tells you to hook up bat. power to the S terminal and switched power to the L terminal.
    I wanted to know why from the factory my Sub. was wired diferent than that. The anwser that I got from my local Alt builder/Guru is that the L terminal is always the switched power. The F terminal is used to show some piece of equipment how hard the Alt. is working. He claims that you don't want to show that wire any power. The S terminal does not have to be hooked to anything.
  6. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    oh, sorry /forums/images/graemlins/dunno.gif
  7. miniwally
    Aug 11, 2003
    3,065
    Colorado
    Not a problem. Thanks for trying to help.
    I did look at a factory wired Alt. today that the only wire running into the plug was the L terminal wire.
    The CS 130 has an internal sensing unit that makes it not need a constant hot hooked into the S terminal.
    Kind of a cool deal for a stock 105 amp Alt. that only needs the battery charge wire and a switched power wire.
