CS144 Alternator upgrade -- Brown wire indicator question
Discussion in 'The Garage' started by Russell, Mar 23, 2006.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    Hey guys!
    I'm putting a CS144 (or whatever the 105 amp TBI alternator is) into my 77 chevy half ton, cause I killed the last one leaving my lights on all night, lol (the truck has a 1500 amp battery in it, It fired up just fine, but the strain on the alternator to re-charge it was too big, and I burnt a diode out)
    The alternator is already mounted, and the big power wire is already run, but I've got two questions.
    First, the red wire excitatory wire. Does a guy need to run that wire to a hot all the time source, or an ignition source? For some reason it strikes me as I gotta have that one under an ignition source so the alternator won't wear the battery down.
    Second, the brown indicator light wire. I am told that a guy can put a 75 ohm 3 watt resistor between wherever that brown wire goes, and the alternator. However, I cannot find a 75 ohm 3 watt resistor anywhere, so I want to run the brown wire to an idiot light in my dash instead (just make it turn the choke light on). How exactly does this light work? Does the cluster provide ground or hot?
    Thanks!
    Russ
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Just hook it up to the factory wires. They are the same color, you just need to change pigtail ends. The brown wire is slightly smaller on the new pigtail but its no big deal.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Yup, I thinjk that because you have the idiot light, you don't need the resistor. The resistor takes the place of the idiot light when your guage cluster has an ammmeter or voltmeter, and no idjit light. There is a good writeup on, I think, http://www.novaresource.org/alternator.htm
  4. Russell
    Jun 23, 2000
    7,922
    333
    The cluster doesn't have an idiot light right now, but that site is very helpful, thanks!
