CUCV Air Force large aircraft tug.
Discussion in 'Complete Vehicles' started by FSJeeper, May 11, 2005.
  1. FSJeeper
    FSJeeper 1/2 ton status
    May 6, 2001
    265
    Texas
    This is a 1985 SWB 4wd, 4 wheel steer CUCV Chevy truck. Has high end ZF axles under it and a very good 4 wheel steer system that gives you several wheel turn options form spinning around on the wheelbase to driving sideways. Frame is like 1/2 inch plate. 4 link system that is beef.
    The axles are the next generation bling axles you'll start seeing more and more of in competitions. German ZF's, exact same axle used in CASE Backhoesfrontend loaders, series 2, for the front axle. They have fluid internal brakes, planetary gear reduction hubs, super light, and much stronger than Rockwells or Mog axles.
    Has the 6.2 diesel, T400 and NP208 Tcase and 7300 original miles. Body and everything else is in excellent condition. Zero rust. Runs and drives perfect.
    $5000
  2. FSJeeper
    May 6, 2001
    265
    Texas
  3. Stratispho
    Stratispho 1/2 ton status
    Apr 26, 2005
    106
    Mesa, AZ
    Pictures
  4. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    You do realize this post is a year and a half old, right?
  5. Stratispho
    Apr 26, 2005
    106
    Mesa, AZ
    Does it say SOLD anywhere on it?? then if not it may be in his backyard collecting rust....
