CUCV Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FSJeeper, Feb 16, 2002.
  1. FSJeeper
    FSJeeper 1/2 ton status
    May 6, 2001
    265
    Texas
    I just picked up my CUCV Blazer. I am putting my M715 project to the side to get this one done. I have a set of excellent condition M1028 CUCV axles to go in it. 4.56 gears, detroit rear, powerlock front, Dana 60/14 bolt.
    I have a 6.2 built up already. I will be putting a web page toegether to detail the buildup. I do not think more can be done to a 6.2. Should do 300HP/500 FTLBS at about 1900 rpm.
    I am going to run an eaton 30% gear splitter/OD and NP205 when I get the time to do the install. In the meantime, I am going to run the stock T400/NP208.
    The CUCV is very low mileage and I will have a nice set of 10 bolts to sell or trade. I need a tailgate, all of the pedal assembly, steering column, etc. to convert this to a standard, and some other stuff.
    Thanks for such a great site!
  2. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    sounds like a nice project. If i am ever in houston i will let you know and maybe i can stop by and give you a hand with something. i may be interested in those 10 bolts when they become available. what gears do they have? let me know and I could come get them!
    Justin
    Austin, Texas K5'er
  3. FSJeeper
    May 6, 2001
    265
    Texas
    The 10 bolts are 3.07 geared, front open, rear Gov Lock. Low mileage.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    What's an Eaton 30% gear splitter/OD ??
    I may be able to help you out on the manual conversion parts. Send me a PM if you're interested.
    <a target="_blank" href=http://coloradok5.com/gallery/75K5>http://coloradok5.com/gallery/75K5</a>
  5. FSJeeper
    May 6, 2001
    265
    Texas
    The Eaton unit is an axuillary transmission that mounts between the bellhousing and transmission. Like a AA Ranger OD/gear splitter unit but a lot heavier duty for big trucks. It is 30% for OD or splitting gears. The trans is a NP435 with NP205 tcase.
  6. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    I'm not sure, so I thought I'd ask... What is a CUCV Blazer? Is it a surplus military blazer?
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74Blazer Topless W/ 35 BFG Muds1" Body Lift W/ Energy Susp. Bushings
  7. FSJeeper
    May 6, 2001
    265
    Texas
  8. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    <a target="_blank" href=http://www.geocities.com/MotorCity/Highway/3969/cucvpage.htm>http://www.geocities.com/MotorCity/Highway/3969/cucvpage.htm</a>
    Austin, Texas K5'er
  9. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    What part of houston do you live in i live in tomball it is outside of houston
    "When you say i drive a fullsize are you calling my wife fat."
    J/K i was bored and made that up i don't even have a wife i'am only 17.
