CUCV Dana 60
Discussion in 'The Garage' started by AZ79K5Project, Sep 1, 2006.
  1. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Front Chevy Dana 60 Military all complete - $1150
    This is being sold around Phoenix. What kind of mods would be needed to a 79 K5 if I were to pick something like this up? I don't have any extra $$$, just asking for future build ideas.
    I've read many threads on the dana 60 swap and but I must be completely brain dead on this issue. I cannot wrap my head around what to look at, stay away from, or seek out.:confused:
    Are these correct statements:
    I should look for a chevy one ton donor around the same year with SRW axle or if I use a DRW - use bigger backspace wheels. i.e Hummer wheels.
    The SRW application will bolt right up, but the DRW will have to have the spring purches moved in a little.
    High steer or x-over would have to be modded on and a 2wd steering box is needed.
    The pitman drop arm has to be reemed out for any x-over or high steer application (including a D44 or 10 bolt x-over setup).
    The engine crossmember has to be redone when the steering is redone.
    U-joints are made to bolt the stock driveshaft to the larger D60 case or I have to have a new driveline built/modded to accomodate the larger U-joints.
    anything else?
    I read Pirates Dana 60 info and it helped some but confused me in other areas. I read some stuff about the Dodge D60. Is that a direct fit also or are there significant mods that have to be done to use one of those?
    The reason I am asking also about the D44 crossover is because I have flat top's in the garage and got concerned after reading a couple of threads about what is needed.
    Thanks for any input anyone can offer...
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I should look for a chevy one ton donor around the same year with SRW axle or if I use a DRW - use bigger backspace wheels. i.e Hummer wheels. Yes
    The SRW application will bolt right up, but the DRW will have to have the spring purches moved in a little. No. All GM front axles have the same spring pad spacing.
    High steer or x-over would have to be modded on and a 2wd steering box is needed. No the stock push pull steering will bolt right up.
    The pitman drop arm has to be reemed out for any x-over or high steer application (including a D44 or 10 bolt x-over setup). No not required
    The engine crossmember has to be redone when the steering is redone. No not required. If you go crossover use a bent draglink.
    U-joints are made to bolt the stock driveshaft to the larger D60 case or I have to have a new driveline built/modded to accomodate the larger U-joints. Front drive shaft is a direct bolt up for all GM applications. 1310 Ujoint
    anything else?
    I bolted mine right up including brake lines as I had a 10 bolt and not a Dana 44 when I started. The dana 44 uses a smaller hole on the line that has to be opened up for the banjo bolt on the caliper.
    Ira
