cucv exhaust
Discussion in '1982-Present GM Diesel' started by stu, Jun 8, 2003.
  1. stu
    stu Registered Member
    May 2, 2003
    59
    Bucks County, PA
    I was looking around today and found a pic of a m1008cucv motr. I was wondering, do all the cucv's come with the stock cast exhaust manifolds. If some didn't, could I get a pic of what ya got. this is whta I found. [​IMG]
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    All CUCV's came with cast iron exhaust manifolds, what your looking at there is a motor out of a HMMWV (humvee).
  3. Dirty Dave
    Dirty Dave 1/2 ton status
    Dec 21, 2001
    101
    Kentucky
    rugger is correct and I happen to have a set of hummer headers for sale if anyone is interested.....Yeah I know it's shamless promotion.
  4. stu
    May 2, 2003
    59
    Bucks County, PA
    ok thanks
  5. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I might be. What's the price?
  6. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    My guess is those headers won't clear the frame rails of a C/K truck /forums/images/graemlins/thinking.gif
  8. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    I have them on my M1009 and it only required the exshaust guys to make a few bends in the start of the system
  9. stu
    May 2, 2003
    59
    Bucks County, PA
    but as u2slow said, will they fit my 82 GMC K1500. I got a hole in the left side manifold and I want to fix it. I found finding a good manifold in my area is very difficult. and I would like to have a little bit bigger.
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Is it an actual hole or just a leak?
  11. stu
    May 2, 2003
    59
    Bucks County, PA
    A hole big enough to put my thumb in. I had an injector go bad and overload the cylinder and burn through the manifold(or so I was told)
  12. stu
    May 2, 2003
    59
    Bucks County, PA
    I got another Question about the above motor. would the intake off of this be any better than a j code intake?
  13. rugger03
    May 14, 2000
    829
    around
    Not enough over the J code intake to notice.
  14. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    A M1009 is a military model Blazer the only thing really different is the glowplug system. When I talked to the exhaust guy that put them on I asked him if it was much trouble and he said nope just a little extra bend at the start.
    As far swaping from a j code alot of guys over at the diesel page think the switch is the first step to getting performance out of a six.2 (damn number key on the office computer wont work)
    Hey devil dog I got your heads boxed up and ready to go.
  15. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just a couple of spotter notes for the HMMWV motors:
    The fuel solenoid, HPCA connectors are the Military style rubber barrel plug. The intake manifold also sits alittle lower than a "J" type. The "distributor" drive isn't a vacume pump but a speed sensor (for diagnostic testing). The TH400 doesn't use vacume for downshifting so no vacume throttle switch either. The fuel feed pump inlet also points a different way.
    There's probably a bunch of other small other differences that I forgot about /forums/images/graemlins/smirk.gif
