CUCV Guage Cluster Tech?
Discussion in '1982-Present GM Diesel' started by kennyw, May 5, 2007.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Has anyone here changed a CUCV gauge cluster over from dummy lights to real gauges? I am converting my CUCV to 12V and started installing a newer gauge cluster when I noticed all the gauge locations are different on the CUCV dummy lights compared to the civilian dummy lights. I'm not sure if I can get away with just swapping out the clusters and changing the sending units like on the civilian trucks?
  2. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    Yes you can swap out the cluster and just change out the sending units and run the wiring.
  3. kennyw
    Jun 9, 2002
    13,223
    94
    The wiring is already there... I'm wondering if the plug into the back of the guage cluster is wired the same between civilian and military trucks mainly.
  4. ccatlett1984
    May 1, 2005
    161
    michigan
    all of the wiring inside the truck will be stock, except for the glowplug wiring. you should be able to just plug it in.
  5. kennyw
    Jun 9, 2002
    13,223
    94
    Thats what I was hoping for... thanks.
