CUCV Headaches
Discussion in '1982-Present GM Diesel' started by Dirty Dave, Apr 15, 2002.
  1. Dirty Dave
    Dirty Dave 1/2 ton status
    Dec 21, 2001
    101
    Kentucky
    Well my head is pounding.....HARD. I have been trying to get the glowplug system in my M1009 CUCV to work normally. When i turn the ignition on the solonoid comes on but wont cycle, the glow plugs stay hot. The wait light comes on very dimly but if I push the throttle it lights up fully. And what does that plug on the throttle pedal go to?
    I have replaced, the solonoid, temp-sender, glowplugs, low coolant module, starter relay, glow plug module, and I not cycleing. I am running a manual switch. What else can i do? I was told to replace the ignition switch but what would that do? The solonoid gets power.
    I cant get my turbo on until i get this licked. Any help would be appreciated.
    Dave
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    My plugs where cycling slow when I had a bad ground.
  3. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    You could replace all the glowplugs with 60gs, run new wires so they are all in parallel, and use a ford starter solenoid with a manual switch. Doesn't get much more simple than that. Works fine in my truck.
  4. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    I already got a manual switch. I want this truck right though, I'm kinda anal that way.
  5. calcide
    Dec 21, 2001
    283
    I suppose you could keep throwing money at it to make it "right" if you want. I prefer simple and functional myself. Emphasis on functional.
