cucv pick up
Discussion in 'The Garage' started by keevy, Aug 29, 2004.
  1. keevy
    keevy Registered Member
    Aug 24, 2003
    36
    Belgium
    I've recently bought a military pick up /forums/images/graemlins/peace.gif; what do I all need, to change the axels swap in my K5 '87 ?
    Which gear ratio is in the 1 ton axels?
    Which locker is in there?...and how does it works?
    Which maximum tyres size can I use with this gears?
    My motor is 350 TBI...
    Sorry for all these questions... /forums/images/graemlins/ears.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    If it has a 350 TBI in it then that has been swapped in. It should have a 6.2 diesel. If its a true CUCV it should have 4.56 gears and a detroit locker in the rear end. The detroit is locked whenever you are on the gas. Tire size is relative but a 37 would be good I think.
  3. keevy
    Aug 24, 2003
    36
    Belgium
    The motor in my Blazer is 350 TBI The pick up is whitout motor and tranny. Thanks for the info /forums/images/graemlins/waytogo.gif
  4. bowtiebstrd
    bowtiebstrd Registered Member
    Feb 13, 2004
    56
    Jacksonville, NC
    it should have 4.56 gears with a detroit locker in the rear. the spring pad width may be a little different, can't remember tho.
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The front axle will be a direct bolt in using all the parts off of the donor truck. The rear axle will require moving the spring perches and shock mounts /forums/images/graemlins/thumb.gif Other than that it should be fairly simple.
  6. kennyw
    Jun 9, 2002
    13,223
    94
    Where are you located... If you are close to the PNW I'd always be interested in helping you "dispose" of the left overs /forums/images/graemlins/whistling.gif
  7. keevy
    Aug 24, 2003
    36
    Belgium
    Belgium /forums/images/graemlins/waytogo.gif
  8. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    the spring perches need to be moved on the rear axle and you need to do something with the shock mounts as well!!! /forums/images/graemlins/weld.gif
  9. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    Most of everything has been said. You may need to modify your existing drive shafts a bit. I believe that the axles from the CUCV are larger than what the k5 uses. 37 inch tires work great for that gearing!
  10. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    is the frame actually narrower or is it just in the srping mounts on the frame?
