CUCV QUESTION, Did they offer A/C at all?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crossy, Oct 22, 2006.
  1. crossy
    crossy 1/2 ton status
    Jul 12, 2000
    257
    southern ,N.J.
    I ask because I stumbled across a heat control unit that says AC to far left and uses cables instead of vacuum to control selection. it looks just like a NON A/C heat control unit but says AC and has none of the other settings like Max air or Bi-level. I thought maybe a cucv item or just any diesel powered rig because they have no vacuum source??? Am i right? I don't have much experience with diesel or CUCV rigs. thanx,Crossy
  2. pos727
    pos727 Newbie
    Nov 20, 2004
    3
    South Florida
    I believe if it was the ambulance version it was yes?
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    The contact truck version also had A/C.
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I have a contact truck, but no A/C. If anyone has one with A/C, I'd like to see how they had the compressor installed. I ran vehicle maintenance in the Air Force and we never had one with A/C, but that doesn't mean they never had them...
  5. crossy
    Jul 12, 2000
    257
    southern ,N.J.
    I got a feeling it may be from any diesel truck from that era.
  6. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Could also have been something done to the individual truck we had as well.
    Our contact truck had the A/C, but it also had some other odds and ends that were added, I know, by the unit.
  7. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Crossy, is that a pic of it? Cuz that's the stock non-AC:confused:
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Looks like where the NON A/C says off , this says A/C , and where the NON A/C fan switch says low , this says OFF .
  9. crossy
    Jul 12, 2000
    257
    southern ,N.J.
    see, pauley383 was awake.
    I know the pic ain't clear but you can see it.
  10. dyeager535
    26,980
    I'll help muddle the issue :)
    That's the heavy duty heater option. Sort of hard to see as well, but both the switch and blend lever are marked "off" and the fan does not work when the switch is in the off position. Doesn't really prove anything, but I believe GM stopped using the "low" fan switch/wiring somewhere in the early 80's, so that clears up the "off" fan switch position. That explains the "off" for the part in question, but not the manual portion of the AC.
    I also noticed provisions for more mechanical hookups on the heavy duty heater setup that aren't used, so I'm assuming that is probably why the unused pieces on mine exist.
  11. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I have had 1009s, 1008s, 1031s and a 1010. 1010 was the only one with a/c thst i have seen. Maybe the gov has some kinda kit to put a/c on?
