CUCV question
Discussion in 'The Garage' started by bear76, Feb 2, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I have an 83' CUCV. It has the blackout light switches on the dash. I want to remove them and run normal headlight switches a such. How do I do it?
  2. dremu
    Feb 27, 2000
    15,957
    448
    East of San Francisco
    Umm, leave the left switch in the center, and the right one in the upper "Service Lights" position... then you just use the headlight switch as normal.
    You COULD rewire the whole truck, but why?
    -- A
  3. bear76
    Oct 16, 2005
    1,065
    here
    Even when working on it I keep bumping the switches which would not be good thing as a DD. Also, thats where I want to mount the wiper switch.
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    does it not have the proper swiches in it? The correct ones have to be pulled out in order to push it up "on".
  5. bear76
    Oct 16, 2005
    1,065
    here
    It has the proper switches. But it does not "lock" in that position, it is easliy bumps back down.
  6. stumblefoot
    stumblefoot Registered Member
    Nov 25, 2006
    20
    Copperas Cove TX
    Just go ahead and wire the blackouts to your headlights, and do away with the switch. Ok so the little lights in front and red ones in back dont help. but you are already wired for some aftermarket lights! whats wrong with the wipers in the turn signal stalk? its cheap to replace and easy to reach.
  7. bear76
    Oct 16, 2005
    1,065
    here
    I went to a manual column, without the stalk. I will switch to a manual tranny later too.
