CUCV questions
Discussion in 'The Garage' started by big_truxx, Jul 2, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    I am doing research to find out what my next 4x4 will be. I really miss not having a 4x4. :( I am thinking k5 or burb but if a k5 more than likely a CUCV would be nice to have.
    the CUCV has a 1/2 ton drivetrain right?
    also they all have the th400/208 trans/xfer combo right?
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    THE CUCV blazers are 1/2 ton . the pickups are 1 ton . all have th400 -208 except the dually version of which some had a 4 spd and a 205 t case . do a search on the net if you need anymore info. :rolleyes:
  3. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :p I was thinking of the blazer version. And thanks for the info it was just what I needed. Sounds like a CUCV blazer would be cool for a mild off road rig. Just what I would be looking for :D
  4. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    My experience with my CUCV; the stock 3.08 gears suck and the 6.2 was in poor shape. From what I understand the military often uses more than just diesel in their vehicles. You also have to watch and make sure the truck has all of its pieces; with budget cuts they have scavenge parts from other vehicles.
  5. cycochevy
    cycochevy Registered Member
    Jul 2, 2005
    9
    pa
    military blazer
    the military blazer uses a hybread 12volt 24 volt charging system they start on 24 volt run 12 glow plugs are 24 volt, the axels are the hd version (large bearing corp 10 bolt front, mine came with 6.2 torbo 400 208 case i changed it to a 700 r4 trans runs good, remember there are NO conferts on the military blazers...most you find on gov web sites are good starters,(,tubs and frames) lots of work myself if you are doing a street ride find a good rust free civilian and start there..
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I want to hear more about this, CUCV 10Bs are the same as civy 10Bs.
  7. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    I never replaced the bearings, so I can't tell you for sure if they are different.
    I did repack the front wheel bearings, so I can tell they are held in differently. Instead of having the spindle nut that you need the special socket for, they have a nut with a removeable key. You have to thread something into a tiny threaded hole to pull the key out. Then the nut comes off.
    Took a lot of time and frustration to figure that out the first time I packed the bearings.
  8. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Not quite right, the 1028s that had a need for a PTO, like the shop trucks with the big air compressor have 400/205s. I've never seen a 4 speed manual in any version of a cucv. If you can document one, I'm all ears.
  9. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    M1008s come with 52 in. long front springs right? Yes I own one but my truck is in another city right now and Im trying to order the ORD extended front shackles. They said if I have 56in. front springs I would have to let them know because the shackle would have to be a diff. size although I dont think i have 56's up front just wanted to make sure though if u guys knew right off. Thanks
  10. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no , stock 47" or whatever it is .
  11. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    it was just heresay that i read somewhere . :doah:
  12. ksmeltzer
    ksmeltzer Registered Member
    Jan 24, 2005
    15
    Florida
    Just one correction the glow plug system on the CUCV is 12 volt for all intents and purposes the only 24 volt component on the CUCV is the starter. As well there is a lower fuse box that runs 24 volt but the rest of the system is stock 12 volt components. Some people convert the system over to 12 volt and add the civilian 12 volt starter but I prefer the 24 volt starter it has a lot more cranking power and turns the engine over like a gasser. You can look here for further information on the CUCV 24v - 12v system http://www.chaosboyz.nl/rubriek/techniek/techombouw12v.htm
  13. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    Here guys...little list for the CUCV's
    Model -- Tranny --T-case -- Front axle -- Rear axle
    M1008...., TH400 - 208 - D 60 open 4.56- 14 bolt ff 4.56 detroit
    M1008a1 , TH400 - 208 - D 60 open 4.56- 14 bolt ff 4.56 detroit
    M1009...., TH400 -208 - 10 bolt open 3.08- 10 bolt 3.08 gov-lok
    M1010... , TH400 - 208 - D 60 open 4.56- 14 bolt ff 4.56 detroit
    M1028 , TH400 - 208 - D 60 l/s 4.56- 14 bolt ff 4.56 detroit
    M1028a1 , TH400 - 205 - D 60 l/s 4.56 - 14 bolt ff 4.56 detroit
    M1028a2(drw), TH400 - 205 - D 60 l/s 4.56 - D70 4.56 detroit
    M1028a3(drw), TH400 - 205 - D 60 l/s 4.56 - D70 4.56 detroit
    M1031 , TH400 - 205 - D 60 l/s 4.56- 14 bolt ff 4.56 detroit
    No 4spds ever used...all 6.2 diesels..for the CUCVs
  14. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    wow! all the m1009 had 3.08's? that's cool in a way
  15. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    new questions
    what kinda hubs do the m1009's run "stock" or normally? manual? auto?
  16. muddog
    Jan 23, 2003
    262
    Cadmus, KS
    manual
