CUCV rear diff vs. 93 rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SubYuman, Jan 4, 2005.
  1. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Is a 14 bolt a 14 bolt, or is my C2500 14 bolt any different? I might be able to get a CUCV diff and save the hassle of swapping gears!
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i dont know about widths on the later trucks, but the cucvs have a detroit locker in them from the factory.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well it depends if you have the SF or the FF.
    14 bolts in the 2500 could be the 9.5" gears (Semifloat) or the 10.5" gears (Full float) plus you need to relocate the spring pads on the axle from a CUCV, but that is easier than changing gears.
    :D
  4. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    14b 10.5 FF
    This the the diff I have. DAMN, I was hoping to just drop in the 4.56 rear out of a CUCV, but you say the pads are a different width on the CUCV diff than mt 14 bolt. Oh man!!o muchfor an easy fix...my 3.73 run like a$$ with my 37's!
  5. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    D'oh!!
    Just noticed my sig said 4.88's... that was the old burb, not this one.
  6. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    gear info
    grab a shim kit and marking compound and switch the carrier and pinion assembely and set up the gears . should be close , possible shim inbetwen the case and pinion unit. oh ya the gear oil also.:cool1:
  7. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    internally close then?
    I understand the carrier is different for the 4.56s, so it is close to just a drop in?
  8. sweetk30
    Nov 1, 2004
    25,552
    545
    axle info
    do like i told you in the last thread, just switch the hole thing carrier and ring gear together it will fit. and check the contact pattern to make sure lined up .:ooo: :rolleyes:
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The carrier is different for the gears.
    It still the same in relation to the housing.
    You can drop in the carrier and pinion assembly, with little work, the 14bff is easy to work with, if youhave some patience and logic that is. :D
