Cummins 6.7
Discussion in 'The Garage' started by yellowK20, Apr 29, 2006.
  1. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    http://www.dodge.com/en/chassis-cab/features/powertrains/index.htmlI was a at the pharmacy this morning and they had an issue of Truck Trends (by motor trend) any ways there cover article was the 2007 3500 HD with the 6.7 liter Cummins TD It's still a L6 but it's designed to run on the new low sulfur fuel that's gonna be phased in this year they say it's still rated the same HP and TQ as the current engine but has about a tenth of the emmisions and better fuel econmy. Any one else heard more about it???
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Cummins announces 2007 on-highway heavy-duty engines
    Mar 1, 2006 12:00 PM
    CUMMINS Inc announced February 12 that its North American on-highway diesel engine product line is ready to meet the 2007 emission standards set by the Environmental Protection Agency (EPA) and California Air Resources Board (CARB). The announcement covered the company's heavy-duty and midrange products and was made prior to the start of the Technology and Maintenance Council's annual meeting in Tampa, Florida.
    Cummins product line for 2007 features a highly successful emissions reduction approach. The engine line will be certified and compliant for 2007 with only incremental improvements. Cummins will continue to use its proven cooled exhaust gas recirculation (EGR) technology with the addition of exhaust aftertreatment provided by the integrated Cummins particulate filter and a crankcase ventilation system. This technology is consistent on all Cummins on-highway diesel engines for North America, including the heavy-duty ISX and ISM, as well as the mid-range ISL, ISC, and ISB engines.
    Cummins 2007-model-year heavy-duty ISX and ISM engines will be available in limited quantities starting in September and will be in full production by early 2007. They will be offered with a full range of ratings (385 to 565 horsepower for the ISX and 200 to 325 hp for the ISM).
    Cummins officials are particularly optimistic about the 2007 heavy-duty engines. According to Ed Pence, Cummins vice-president and general manager of heavy-duty engine business, “With more than 300,000 cooled-EGR engines on the road, and over 30 billion miles of experience, we are confident in the customer advantages provided by our 2007 engines and emissions solution. We believe Cummins is the only company with the key in-house technologies that enable the engine, air handling, and aftertreatment system to be totally integrated for optimal reliability, durability, fuel efficiency, and low cost of ownership.
    “Our 2007 field testing is well ahead of schedule. Field tests have been jointly conducted with OEMs and end customers, so we are able to validate performance of the entire system in real-world conditions and duty cycles. Under all conditions, performance has been impressive.”
    Steve Charlton, Cummins 2007 Heavy-Duty Program Leader, said, “At the heart of our engine system is our proven variable geometry turbo. And at the heart of our aftertreatment system is a DOC (diesel oxidation catalyst) and diesel particulate filter. The engine and aftertreatment perform as a system to meet the 2007 emissions standards and maintain fuel consumption comparable to current levels. Incremental improvements for the ISX and ISM for 2007 include an electric actuator for the VG Turbo which provides faster response and improved precision in adjusting airflow to the engine, improved EGR subsystem with a high-performance cooler, and a faster ECM (Electronic Control Module).”
    The Cummins Particulate Filter works together with the engine as an integrated system (both are controlled by a single ECM). The filter removes particulate matter from the engine exhaust by passing the exhaust gas through a ceramic wall-flow filter. The particulate matter is collected in the filter and later oxidized to produce clean exhaust at the tailpipe. The particulate filter's primary mode of operation — over 85% of the time in most applications — is passive regeneration, which automatically occurs during engine operation.
    As part of its complete aftertreatment solution, the Cummins Particulate Filter provides active regeneration if passive regeneration does not maintain low carbon loading. The ECM will initiate an active regeneration event so the catalytic reaction can take place. This infrequent event is completely transparent to the operator.
    The Cummins Particulate Filter is designed to last the life of the engine. However, periodic maintenance will be required to remove the ash content. Service intervals will vary by duty cycle, but could be up to 400,000 miles (640,000 km) in most line-haul operations. The Fleetguard Enviroguard coalescing filter captures and filters crankcase emissions. It requires changing every third or fourth engine oil change. Oil and oil filter change intervals will remain the same in 2007.
    Turning to the mid-range engines, the 2007 ISB will see displacement increase from 5.9 liter to 6.7 liter, providing more horsepower, more torque and, more importantly, more performance for customers. Jeff Weikert, Cummins 2007 MidRange Program Leader, said “Our 2007 midrange and heavy-duty field test units have already completed over 2.5 million miles in field testing that encompasses all altitudes, temperatures and conditions, and over 20,000 abusive test cell hours. We have shared our experience across platforms to create a very solid lineup. We believe customers will really like the increased performance of these engines.”
    The midrange product line for 2007, including the enhanced ISL, ISC and ISB engines, will use Cummins' proven cooled EGR technology with the addition of exhaust aftertreatment provided by the integrated Cummins particulate filter and a crankcase ventilation system to deliver certified and compliant power. By using this common emissions solution across all on-highway engines, Cummins leverages its proven technology to meet 2007 emissions standards while at the same time delivering superior reliability and increased performance.
    The entire Cummins midrange line will continue to use high-pressure common rail fuel systems, enhanced for 2007 with higher injection pressures to optimize fuel economy and increase performance. All engines will use the patented sliding-nozzle VG Turbo, which doubles as an exhaust brake with increased braking power in 2007. Also new in 2007, the VG Turbo features a new electric actuator with faster response and improved precision in adjusting airflow to the engine.
    Enhanced electronic engine controls will increase the number of injection events per combustion cycle, so the ISB will continue its position as the fuel economy leader with the lowest total cost of ownership in its class. An automatic oil level sensor option eliminates the need for daily oil level checks. And, a new 18-quart oil pan option allows for standard oil drain intervals to be increased to 20,000 miles. The ISL, ISC, and ISB all share an enhanced electronic control module with greater speed, memory, and flexibility. The ISL and ISC both offer an optional compression brake.
  3. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Theres a picture of one in the latest four wheeler.
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i think the real story is gonna be fords 6.4 keep hearing rumors about twin turbos and damn near 700 ftlbs
    but then what do i know :D
  6. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    yeah I've heard some TT duramax rumors. also I read a little blurb in 4wheel and offroad about the current P-stroke something like 66 tsb's and 16000 consumer complaints and 60 lawsuits not exactly sure on those # but my point is I wouldn't buy a ford diesel theres just to much crap to go wrong on those motors especially the 6.0
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I think it was like 76 TSBs. I was talking to my neighbor who had a 6.0 excursion (just sold it) and he said he had to take it in a few times, and has gotten a bunch of recall letters. It only had 17K on it.
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I work with a guy that has a 03 F350 with the 6 liter, the entire top end of the engine is being replaced right now. The bad thing is all he does is drive it to work, no towing of any kind.
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    03's and 04's are the worst years.
  10. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Yeah most everybody I run with has P-strokes for work trucks or tow rigs (I have a V-10 in my superduty which I like ) the 6.0 trucks seem to have the most trouble
  11. Propayne
    Propayne Registered Member
    Nov 27, 2005
    67
    San Angelo, TX
    in no way, shape, or form am i trying to start a flame or flaming on anything, but i have to say i believe that Ford had their diesel tech together way before chevy did. the Powerstroke 7.3 is an amazing engine. Stock it has great ponies and torque and if you chip it, it can pull a building down. now the 6 leaker is a piece i admit...and Duramaxs are a really good diesel(and cummins is well, cummins) but when Ford gets the kinks out, i think they will be the leader in Pickup Truck diesels.
    just my .02
  12. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Well I think the Non-power stroke 7.3 turbo and the non turbo 7.3 are better than the powerstrokes but that's personal preferance there . are tool truck for work is a97' stroke with 270,000 miles og high abuse and the only repairs it's needed was a auto tranny 190,000 but my boss's personel truck is a 2002 and he's had a bunch of crap on his cam sensor, head gasket,water pump,turbo,glowplugs,injectors,computer and it only has 47,000 on it . from all that I've seen I wouldn't buy a ford diesel . There nice trucks with awesome power to be sure but there relabilty is supect
  13. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    It's an International engine in the Ford pickups. You can thank (or kick) the good folks at IH for the 6.9 7.3 & 6.0.
    But I agree the international 444 was a stout mill.
  14. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    My Mom has a Non turbo 7.3 (with a banks turbo kit) with nearly 600,000 miles of horse trailer pullingit still runs like a raped ape . it's had the normals done (waterpump ,glow plugs, injectors) But for the most part it's been trouble free
  15. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Ive got a bud with a '96-'97-ish (can't recall exactly) F250 ext cab 7.3 4wd, he's tapping near 900,000kms hard oilfield work km's hasn't had any major problems with the engine. Just clock work maintenance and minor doodads.
  16. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    My 93 K3500 has a 6.5 in it and has 456,000 on it nothing done to it but a clutch,radiator and water pump My father inlaw used it Hard on the ranch with out much care I mainly use it for dump runs and parts hauling now but it still starts and runs good I'd drive it more but it has wasted IFS
  17. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Ya my '98 Dodge 2500 24valve only has 145,000kms on it.........I'm still working hard on that number :D
  18. yellowK20
    Dec 26, 2002
    7,602
    553
    Wasilla AK,
    Man I'd love to have another dodge I use to have a 93 it was awesome I really think That Cummins makes the most relable Diesel engine period Caterpillar is good but there parts are expensive and sometimes hard to get(from other than cat) But you can practically go to wallmart and get Cummins stuff
  19. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    ford owns cummins, so why dont they put the cummins in the ford trucks?
  20. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Please for the love of god stop spreading that myth.
