cummins conversion... need help with a couple of questions
Discussion in '1982-Present GM Diesel' started by chevyracing, Mar 12, 2002.
  1. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    A friend wants to convert his dually (chevy) to a cummins.. Need some info, web site addys, phone numbers, etc.
    He has a blown up 6.5 turbo now.
    John
  2. Joey D
    Joey D Registered Member
    Mar 20, 2002
    42
    Arlington MA
    I have looked into this plenty. The only problem is cost and room. The Cummins is long, and makes a tight fit to the radiator. Then the intercooler, also a tight fit if it fits at all.
    There are some good options for the 6.5. A rebuild on a good block with 18 to 1 pistons and good head gaskets, marine injector pump, GM-8 turbo, intercooler. Will give 275hp or more to the wheels.
    Thats plenty for most, but the ultimate power motor would be the Cummins.
    It comes down to how much $ do you want to spend.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    <a target="_blank" href=http://forum.62-65-dieselpage.com/ubb/ultimatebb.php?ubb=get_topic&amp;f=6&amp;t=000142>See if this is any help.</a>
    There's a gentleman over on <a target="_blank" href=http://www.thedieselpage.com>The Diesel Page</a> who is in the process of converting his 95 Suburban to Cummins power as well....but he hasn't posted much info yet.
    Casey
  4. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    I will pass this info on to him. Now I have two friends considering this swap. I think what they are after is longevity in the engine. Not saying some 6.5 Turbo Diesels are not capable of running the miles a Cummins is, but more likely to with a little less hassle. I know before Mudnutt blew his 6.5 up it would smoke my Cummins off the line.
    John
