Cummins conversion question...
Discussion in 'The Garage' started by DieselBurb, Jan 13, 2004.
  1. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    If I can find one in my price range, I am wanting to convert my 6.2 /forums/images/graemlins/burb.gif to 5.9 CTD. My question is: does the CTD have the RPM for my TH400/4.10/33 setup? I want to be able to cruise at highway speeds (normal speeds that is /forums/images/graemlins/wink.gif)
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    65 mph = 2713rpm
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Depends on what year you get.
    The '89-93 with VE rotary pumps are governed to 2500rpm.
    IMO a TH400,4.10s and 33s would be pushing it for highway driving.
    I had a 1990 dodge for a while. It had a 727(3sp), 3.07s and 30.5s. I wouldn't want to push running 4.10s without OD.
    As far as the RPM charts go, do they include an extra 200 rpm for converter slipage? They will have more/less depending on what load is being pulled. Even the converter in my old '88 crewcab showed a noticeable rpm difference from empty to loaded at ~2500rpm.
  5. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    Can you just bolt a th400 up to a cummins or do you need a special mounting plate made up for it
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Dodge cummins motors have a different bellhousing pattern than GM but GM cummins are known to exist in commercial vans.
  7. Stomper
    May 11, 2002
    3,767
    Iowa
    There is a cummins/gm adapter from a p30 van. You would need the adapter, flywheel, torque converter spacer and starter. Along with some other odds and ends.
  8. Stomper
    May 11, 2002
    3,767
    Iowa
    I wasn't trying to imply that the engine would or could turn those RPM's but those numbers are close to what the combo would generate.
  9. Grim-Reaper
    7,385
    Atlanta
    I'd look at OD like a Gear vendors or at least go to a 35 inch tire to Get the RPM's down a little.
  10. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Mosesburb is currently installing a 5.9L cummins in a 72 Burb...my old burby. He will be using a NV4500 with a NP205 and a doubler i believe...pm him about the adapters.
    The p vans did run the 4 cyl version of the cummins...
    DW
  11. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    65 mph = 2713rpm
    I've got a '93 dodge cummins
    Redline is at 3000rpm
  12. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Im lookin to throw a older 12Valve Cummins in my GMC sometime down the road(3-4 years), would a 700R4 work with that P30 stuff? It will be a built 700R4 and would be able to handle the power...till i get to crazy.
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I am probably the member that is most loyal to Th700's but even I would have to rethink using a 700 behind a cummins. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
  14. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I second the doubt about a 700 behind a Cummins. My friend smoked the Getrag in his 90 cummins 4x4 so I dont think a 700 would even get you out of the garage. If you want to keep the 33's I'd get like 3.73 or even like 3.42 gears because that engine has more than enough power for that combo. Good luck with the swap.
    PS...do a writeup /forums/images/graemlins/thumb.gif
