Cummins, Duramax, Powerstoke?
Discussion in 'The Garage' started by BIGCHEVY4X, Jun 5, 2005.
Which Diesel is best?
  1. Cummins
    106 vote(s)
    45.7%
  2. Duramax
    65 vote(s)
    28.0%
  3. Powerstroke
    16 vote(s)
    6.9%
  4. CAT
    31 vote(s)
    13.4%
  5. Detriot
    12 vote(s)
    5.2%
  6. Other
    2 vote(s)
    0.9%
  1. BIGCHEVY4X
    BIGCHEVY4X Registered Member
    Mar 16, 2005
    52
    El Cajon, CA
    I am curently running a GM 6.2 in my truck but later want to upragde to a Cummins. I wanted to see what you guys thought about the new diesels. Ive heard the Duramax and powertoke were only made to go 150K whiel the Cummins can push 500K with routien maintance. Cummins is a heavy duty power source and is used in all sorts of applications and has been prove to work and to last. Also with it being inline it is easier to work on. I dont know how they compare in proformance though. What is your opion?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Depends on application. Detroits are used the most in OTR rigs followed by CAT then Cummins. All three diesels for light trucks break down like this :
    Powersmoke = 250,000 mile plus life
    Duramax = 300,000 mile plus life
    Cummins = 300,000 miles plus life
    At least that's what I 've seen
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i like the newer cummins... 600 ft lbs at 1200 rpm with 300k+ reliability is flat out bad ass.
    j
  4. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    The D-max should be a 300K mile motor, but i dont think anyone can say that it is yet. Seeing as how the D-max has only been arround for a few years, there have been very few to make it even past 200K miles. Not because of problems, but because they haveant been on the road long enough. Nobody knows what that motor is capable of lasting, simply because its still to new. Powerstroke's have been arround longer than the D-max and there are WAY more of them on the road, mainly because of fleet vehicles. With routine maintinence they easily make it to 300K(Im talking about the 7.3, again 6.0's are to new to really judge)
    All are good motors, and all have their advantages and dissadvantages. Keep them maintained and all 3 should make 300K without to much of a problem, so long as they arent abused the whole time.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i think the current PS is in the same catagory as the duramax, in fact the current duramax design has been around longer than the current PS design if I'm not mistaken.
    j
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Thats why i put that little tidbit in parenthasis in there ;)
    Although to get technical, there are a lot more 6.0's on the road than D-max's. But International doesnt call them powerstrokes, they call them VT365's. They get used hard, and are proving to be a good medium duty motor.
  7. 1-ton
    Apr 17, 2004
    2,885
    165
    Las Vegas, Nevada
    CAT is the best, but you cannot get one of those in a passenger truck (at least any passenger truck that I am familiar with).
  8. BIGCHEVY4X
    Mar 16, 2005
    52
    El Cajon, CA
    would it be that hard to fab it to fit?
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think that Detroit is the first most used in OTR trucks, followed closely by Cummins, and then Cat. In my driving history I have only drove 2 trucks with Cats, but over 2 dozen with a Detroit or Cummins. I don't know of any major fleet operation that uses Cat engines either because of the higher cost of maintenance and the need for a rebuild sooner than a Detroit or a Cummins. Simply put - on average, a Detroit or Cummins WILL outlast a Cat when used in an OTR truck.
  10. 1-ton
    Apr 17, 2004
    2,885
    165
    Las Vegas, Nevada
    I have a few years experiance OTR, and what you say is mostly true, but from my experience, the main reason for CAT engines not being used in fleets is because CAT engines are expensive high quality engines (which also comes with a big price tag for repair when needed, but not anymore often then the detroit). Detroits are the best alternative to a lower initial cost and still have quality.
    The ultimate big rig would be a long nose Mormon or Western Star with a CAT engine, but I would settle for a Freightliner Classic with a Detroit.
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    fixed it for ya....
    i love mine. no problems with the motor... trcuk on the other hand... dang dodge gets on my nevers now and then. no problems with it, just little things here and there.
    Grant
  12. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Just quoting on what I see roll into the shop on a day to day basis
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    For whats available today in a light pickup.....Cummins for sure. The best diesel out there...JOHN DEERE. JD makes the best engines period! Supposedly JD helped design the Series 60 Detroit motor, which is the best in OTR and is now a legend in the OTR motor world. I've owned and operated a lot of diesel engines and JD's are the best I've seen.
  14. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I have had 3 powerstrokes in the past all were the 7.3
    I think Ford is the way to go. Most of my buddys have Diesel trucks
    I can tow the passes here in colorado at 65-75 mph loaded 3k camper in the bed
    18ft dovetail trailer w/k5.
    My buddy with the Cummings is just as strong as my PS.
    On the other hand we have a buddy with a Dmax and damm that thing is slow
    and has a hard time pulling the load on any hills. He thought it was just a lemon of a truck so he traded it in and bought another Dmax same thing as the first.
    So I think all of the three big trucks out there you cant go wrong all should last
    300k if taken care of. It just depends on what body style you like the most.
    Then agine my .02 worth
  15. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    :what:
  16. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Fixed it for ya. :)
  17. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Out of curiosity, how many miles do you have on your 6.2?
  18. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Um no, you didn't.
  19. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    On rolled in yesterday. 1.5 million miles on a series 60, of course it had some rebuilds.
    The main problem with Detroits is the damn fuel line heading to the back of the cylinder head. They all are routed poorly and tend to leak. We get one every day with a fuel leak.
  20. BIGCHEVY4X
    Mar 16, 2005
    52
    El Cajon, CA
    I dont know how many miles my current 6.2 has becuase i bought it seperate from a vehical, but the original 6.2 had 280K and ran beautifuly untill the idiot overheated it and blew the heads
