Cummins in '93 C30 info
Discussion in 'The Garage' started by Diesel Dan, Aug 3, 2005.
  1. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    Warren, Ohio
    This is for kennyw's question in the diesel forum.
    Your NV4500 will not accept a dodge/cummins input shaft without modifcations. The input bearing retainer is too small in the '92-95ish GM NV4500s. Also the two upper bolts will fit a cummins bellhousing but the lower ones will not. I've been down this road, worked on installing a 5.9B Cummins in a '93 K2500 ext cab about year and a half ago. Best bet would have been going with a remain NV4500 for a dodge/cummins with GM output shaft. Around '95 GM went with the larger input bearing retainer, so the trans shops told me.
    I still have the bellhousing, flywheel and NIB clutch kit from that project.
    Heard of a web site that offered motormounts for that conversion however I didn't save it :doah: .
    Another thing I thought would be cool was using a stock dodge intercooler with a single headlamp core support. The single headlamp support had enough room between the headlamp buckets for the in/out lets.
