Cummins swap, yee ha
Discussion in '1982-Present GM Diesel' started by tacoma, May 28, 2006.
  1. tacoma
    tacoma 1/2 ton status
    Jan 14, 2005
    317
    tooele UT
    Next week I get my Cummins, it's going to rock. Stem to stern, everything included all the way back to the t-case.
    maiden voyage????
    trip to UT with the family.YYEEEEE HA!! hahahahha
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Congrats !!!
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    4 or 6?
  4. tacoma
    Jan 14, 2005
    317
    tooele UT
    full on 6bt, 1st gen, VE pump, w/a 47RE OD trans, all the wiring, Banks intercooler, etc. Still need to pick up a 205 for it, since the sweet 241HD is the wrong side drop (so no sweet 2.72:1). Bummer!
    Hopefully I can get it to fit without any trouble.
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    What do you have for a front axle right now? Why not just pickup a 78-79 Ford high pinion D60 (78-79 Ford D44 if you have to get by for a while will work too) for the front and keep all the good parts your getting with the Cummins?
  6. tacoma
    Jan 14, 2005
    317
    tooele UT
    Because a Ford 60 is like, 8 trillion dollars in UT (or like, $2500 LOL ), whereas the 205 is $300.
    Since last post I have decided to go with a new input gear for a Chevy 241 and make an adapter. The 241HD was a plow upgrade for the 3/4t Cummins trucks, which is what the trans/Tcase ended up being out of. We both thought it was out of a one ton, but I counted splines.... 23. :( but that's ok, it's not going to use the 4wd much anyway, mostly a tow rig/hauler... that might get stuck in mud or something and need more wheels pulling LOL
    if it wasn't so much more money, hell yeah, I'd get a Furd 60. But it is, so I get a new input gear instead. LOL
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    The truck didn't neccessarely need to be a plow truck, at least on models a few years newer than what your VE 6bt came out of, 3/4t came with both cases.
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You say it's coming with a 47RE...did that come out of a later truck? That engine should have a 518 behind it, far as I know, which is nearly the same trans without some upgrades and is full mechanical.
  9. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    518 were until 93 ,In 94-96 cummins had 47rh, In late 96 cumiins had 47re and so on ..
    CrewCab59
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Are your motor and trans from the same truck? If you have a 47RE from a 96 Cummins then you should have a P7100 pump cummins not a VE pump. The P7100 is all mechanical and is the best pump they had sofar.
    Harley
