Curb Climbing, White Smoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GaDawg, Jan 30, 2003.
  1. GaDawg
    GaDawg Registered Member
    Jan 14, 2003
    21
    Georgia
    Just messin around in a parking lot one day and tried to pull up & over a curb. I was in 2 wheel drive high, My K5 didn't go anywhere and white smoke with a distinct odor came billowing out from under my truck as I applied gas. Any ideas? Do I need to have my hubs & transfer case engaged for any kind of wheeling?
    Truck Info:
    1985 K5
    350 C.I.
    4-speed manual SM 465
    Stock 10 bolt front & rear
    SuperWinch manual front hubs
    32" All Terrain's
    All maintenance is current. Front & rear Diff. serviced, brakes, transmission fluid replaced, clutch & master / slave cylinder, oil, joints lubed, etc.
    /forums/images/graemlins/usaflag.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    You broke your rig while curb crawling??????
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/1zhelp.gif
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    White smoke is usually coolant. Did a hose come off? I would hope you don't need to engage 4 wheel drive to get over a curb /forums/images/graemlins/1zhelp.gif
    John
  4. GaDawg
    Jan 14, 2003
    21
    Georgia
    I think that may be it. I took my truck back out and did some hill climbing & mudding and didn't get the smoke again. After the smoke incident I did notice that my overflow container for the radiator had leaked some coolant out. Although the distinct odor wasn't coolant, it smelled more like the clutch. The clutch was put in about a year ago, shouldn't be sitting there & slipping.
  5. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Did you roast you tires? They will produce white smoke.
  6. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    coolant, tires or clutch..... hopefully it wasn't the clutch! Those are the only things in my mind that will create white smoke in a vehicle
  7. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    First guess is clutch.If you gassed it before clutch was fully engaged slipping is poss.You would have heard tires spin{left black marks too}Rad hot enough to cause steam wouldn't cool off very quick. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  8. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    -Dan
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The angle your truck was at probably caused the coolant overflow tank to overflow and spilled onto the engine, producing steam
  10. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    what did the oder smell like....sweet?roton eggs? melted boggers...lol? id have to go w/ the clutch
  11. punkass
    punkass Newbie
    Jan 25, 2003
    Probably not in a parking lot.
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my vote is clutch. Both coolant and tires make a smell any backyard mechanic worth his weight in tire rubber should know. When curb popping in a manual you got to let the clutch out slowly and apply gas slowly. When she starts to sound like shes gonna stall then you start apply the gas but like I said just enough so she doesn't stall the whole time. Or get a running start /forums/images/graemlins/smile.gif believe me wailing a curb at 25MPH don't burn the clutch. It makes some metal vs metal noises that are interesting but no smoke.
