Cured my driveshaft vibration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Apr 13, 2001.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    Thanks for the advice some of you gave me on my driveshaft vibration problem...last week I installed my 4" lift and the bla...ah....jimmy looks great. I had a slight vibration at 30-40 mph. but hell...was it something else? you know your speedo is not right after the lift. anyway...I droped the xfer case down using the gm spacers on the xfer case xmember. It works like a charm and no worries now. Cheapest mod I've ever made. by the way...where can I get a grease seal for my front driveshaft? when I dropped the front axle to install the new springs you could see my driveshaft splines...the seal broke off and now I need to keep that grease in. I'm asuming it's easy to put back on. but you know what happens when we assume.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It is called a zurk fitting. I don't think that is how it is spelled. But that is what it sounds like. You can get that at any auto parts store....
  3. lehtola
    Mar 21, 2001
    192
    North Carolina
    Thanks. I'll check into the zurk fitting.
  4. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Its spelled zerk....should be able to find one in any parts store
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Thanks..I was close anyways...
