Curious Metal on Metal Sound.... Any ideas?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cashew, Sep 8, 2003.
  1. cashew
    cashew Registered Member
    Sep 12, 2002
    11
    SF Bay Area
    Ok, so my '75 has been running really well for the past year or so. Fouls the plugs every now and then, but normally that only happens if I get lazy and run the cheapo gas. However, this past month, the truck has started to develop a strange scrapeing sound.
    Symptoms:
    Started with a barely audible light scratching noise while at idle in Drive. Put it into park or reverse, and the noise would stop. Drive, L2, L1 and Neutral all had the scrape. Checked the engine, tranny, and Tcase oil, all in good condition.
    The noise has now progressed to being in all gears, so I'm fairly certain it's not the transfer case. I only hear it in the morning, when I fire up the truck for the first time. By the time the truck is warmed up, the sound stops. It definately sounds like it is coming from the transmission/engine area, but that is just by listening in the cab and under the truck.
    No lack of power, no noticeable jumps in the tranny when it shifts, and no shimmy from anything seeming to be out of balance.
    Truck Details:
    1975 K5
    350, 4bbl carb
    TH350 Tranny, NP203
    Dana 44 front, 14 bolt corp. rear, Warn Hubs, 33's, stock open diffs front and rear (yech, got to fix that at some point)
    So, does anyone have any ideas? The motor and tranny and tcase are all stock original, so they have 250K miles on them so far. Getting pretty old, but if I can get an idea of where to look, maybe I can replace some parts, instead of the entire units.
  2. seanp
    seanp Registered Member
    Sep 3, 2003
    68
    S.E. KS
    On my 79 the motor mounts were shot causing the harmonic balancer to rub on the engine crossmember.
  3. Grim-Reaper
    7,385
    Atlanta
    Same problem I had on my 75.
    Might want to drop the inspection plate and make sure the torqconverter is not coming loose. Looks for any metal dust in there as well. If the flex plate is cracking it usualy leaves some fine metal dust in the bellhousing.
  4. cashew
    Sep 12, 2002
    11
    SF Bay Area
    Good tips guys, thanks. I'll dig into it this weekend.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    It's good to check every couple of weeks for imports stuck under your K5. Maybe that's your problem.
  6. cashew
    Sep 12, 2002
    11
    SF Bay Area
    Finally got some time to dig into the blazer, and sure enough, the harmonic balancer is barely scraping on the crossmember. SO, got an order in for some new motor mounts.
    Thanks again guys, this forum saves me money every day! /forums/images/graemlins/smile.gif
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I would replace the tranney mount while you are doing the motor mounts
