Curious
Discussion in 'OffRoad Design' started by bherring, May 4, 2002.
  1. bherring
    bherring Registered Member
    Nov 2, 2000
    55
    VA,USA
    Stephen,
    If you were on some nice pavement in your rig, 4low/low, and mashed the go pedal, what would happen? Does it smoke all four? Just curious. I'm scared to try.
    Take a look at the new bodystyle on the site below.
    Thanks.
    -Beck.
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    u wont exactly "smoke" all four unless u have lockers, bulletproof axles, and are chained to somethin to hold ur ass still. But, u may possibly squeal them. other than that u will just have some badass acceleration.
    NITRO
  3. bherring
    Nov 2, 2000
    55
    VA,USA
    That's why I'm asking who I'm asking.
    I want to know if those meats break free from pavement or not.
    Thanks, Beck.
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I don't think so. I remember Stephen talking about the acceleration testing during the TTC, and he said that in 2WD low range (2:1) it would leave rubber for a short ways. I don't think it would in 4WD. But it's just a guess.
  5. chief chiba
    chief chiba Newbie
    May 6, 2002
    3
    we shall see
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Pour a little water around the tires to get them started and maybe you could smoke all four. By the time the waters gone the tires should all be spinning.
  7. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    ill try at the track tomorrow and let ya know
    NITRO
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Use bleach instead of water.
  9. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    i will seein as how i will b at a track. /forums/images/icons/smile.gif
    NITRO
  10. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    have somone take some pics, itll look tough,
  11. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You would need Big power to turn tall tires over on pavement. I tried to burn my 44 TSL's on my concrete driveway in granny gear two wheel drive high with a 35 spline Dana 70 rear and I snapped an axleshaft. I would have a hard time imagining burning all four. It seems like if you had enough power you could burn all four, but most of us have to rely on gear reduction to turn out big tires and you just couldn't get the wheelspeed needed to truly break them loose. My rearend is welded and I can burn the rears forward or backward on WET pavement. I decided not to try anymore on dry.
  12. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    L.M.G.D.F.A.O.!!! been there ..done that...and with 1/2 ton gear and 35's, i blew a brand new rear and eaton 350lb posi.. its dumb, dont less ya got 1 ton gear!!
  13. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    got rained out...not goin to the track today. ill try it in the street and piss off the neighbors
    NITRO
  14. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my dad's buddy tried this with his 79 furd pickup and blew EVERY u-joint in the truck! the driveshafts, the front axle and the stubby shaft between the tranny and t-case. i wouldn't try it unless i had 1 tons and 31"s.
  15. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I've tried just nailing it a little and with low range you will definitely not get the wheelspeed you need to burn em. Maybe a chirp if your lucky. Its funny, I have an auto and it couldn't upshift fast enough to keep the engine from redlining. When it did hit the next gear though it would about toss me into the back. Pulled the front mounts to my seat loose!, which wasn't too hard I reckon since there isn't much sheet metal left to hold em, LOL. That was with a stockish 350, 700r4, 208, and all 1/2 ton, sitting on 33 bfg mt's.
  16. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    nitro may be able to do it... we'll see. His rig certainly has the power. If he had some smaller tires, I'm sure he could do it...
    J
  17. bherring
    Nov 2, 2000
    55
    VA,USA
    Yeah, I just know Stephen has both the power and the durabity (1-ton). I broke the joint at the back of the case when I tried to brake the swampers (35 psi) loose on pavement in low range. Needless to say....I was very disappointed. Whatever. We shall see. Nitro...what do you have that makes you think you can rip it? -Beck.
  18. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    as his name sorta implies... a huge big block + nos system....
    J
  19. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    heres the deal... the K5 will squeal but not lay down a serious piece of rubber unless its assend is strapped to a house. with that said, the 555cid mud bogg/show truck will get them to smoke, but it isnt exactly like a burnout in a funny car. but, the k5 will do a hell of a nice burnout in 2hi. and that is with 1/2tons. so there are the results.btw, the 555 has usually has 44"boggers,but burnout was with 31"coursers. the k5 is alot of fun for burnouts on [censored] tires /forums/images/icons/smile.gif
    NITRO
  20. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    In 2wd single low it left some black, that was at low altitude (TTC) though. Up here I don't know if I could get them to break loose in rear single low and I don't know about getting enough wheel speed in double low, and the added traction from the front would probably just launch it hard to the redline. It will spin all four pretty easy on fairly tacky slickrock when it has a strap and anchor I just don't think it has the off-the-line jump in power to get them all broken loose when it can accelerate. Up here the torque converter stall is somewhat low, at TTC it was pretty lively since the motor comes on strong in the mid 2000 rpm range and the torque convertor stall was about 2400. It launched scary hard for a guy used to a small block at high altitude!
