Custom antenna mounts
Discussion in 'Communication (CB | GPS | HAM)' started by berg76, Mar 30, 2004.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I was wondering if anyone has made a mount that works with the bolt holes that hold the hard top on? I was thinking of making one straight out the back using the last bolt. What do ya think? /forums/images/graemlins/ears.gif
    ~Jason
  2. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Should be doable, but you need to be able to seperate the coax from the ground.
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Sounds like a simple concept. The only problem I would see is with water leaking in from the top not sitting right.
