Custom beadlocks revisited. Update, 8-25-05
Discussion in 'Vendor Forum' started by cybrfire, Aug 17, 2005.
  1. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Like I said not something most folks from this board will ever need or want but interesting none the less,
    I think you'd call this a 24" rim. The guy is running 48" (35x16.5" next to it)Tractor tires on his rig. We set one next to my 44 and they are just friggin huge. Not too wide though. The rims are custom made so they can be turned around. I guess so the tractor tires don't dig so much. The beadlocks are a variation of the double ripper design inside the lip weld ring with 40 3/8" bolts. In case the guy I'm making these for reads this, I'm not helping you torque the bolts. I'm going to have a beer and watch :haha: . Amazingly enough the sidewalls on the tractor tires are a bit more pliable than an SX. Not quite as soft as my TSL's but soft enough to make airing down worth while. The biggest benefit I see to these tires is the clean out factor. For sure better suited for mud than anything else. He says they do all right on pretty much any terrain. He wheels it alot and wheels it hard so I can't argue.
    When they are finished and mounted I'll get some pics of the whole truck.
    Anyway, thought you guys might like to see what some guys are doing to master the mud!!
  2. primetime
    primetime Registered Member
    Jul 18, 2005
    22
    sa,tx.
    i say sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Nice.
    Got a pic of the tire he runs?
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I will have soon. I'll update this post when I do.
  5. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Was wondering if this is what you were refering too... :D Those rims looked huge but they look bigger with the beadlock on them. Let me know when he's going to mount them, I could use a beer :haha: :haha:
  6. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I think he plans to pick these up Tomorrow, some kind of trail maintenance run to attend on the weekend. Hopefully he brings a tire along so I can get some more pictures but I kinda doubt it.
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Dang! Those are huge!
  8. tacoma
    tacoma 1/2 ton status
    Jan 14, 2005
    317
    tooele UT
    If you want to get me a price on a set of 20's with a Rockwell pattern, I may be one the "not many" that ARE interested!!! lol
  9. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I don't have a set of 20's to measure so you may have to do the measuring or ship me a rim!
  10. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Sort of Off-Topic but what would you charge per rim to do the welding? (15's in my case, but I'm sure some other people would be interested)
  11. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    For straight up Mig welding shop rate is $35 per hour. If you clean the edge of the rim and prep it up. It doesn't take long to do a set of beadlocks. I'd estimate and hour. If I do the prep work its closer to two hours.
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    :yikes: That's way less than the beer would cost for a wrench session to get someone to do it for me...not to mention your welds would probably actually hold air. :D
  13. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Well, the way I weld them up is to have all four prepped and ready to go. Tack weld all 4 rings in to place. Then I do 4 welds on rim 1 at the 12,6,3,and 9 (edit, in that order)oclock positions and move on to rim 2 and so on. By the time you get back to rim 1 its pretty cooled down and your not waiting. The big ones pictured at the top took a bit longer but if you figure it out that's almost 27' of weld. :doah:
  14. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    What is the thickness on your weld on rings? I looked around but couldnt find it?.
  15. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    1/4" thick on both rings.
  16. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I bet they make those puny 16.5 rocklocks I ordered look well,puny...:D
  17. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    only see red X's????????
  18. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Old thread! The pictures were of a 24" beadlock for a tractor tired rim if I remember correctly. Double ripper style.
  19. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Lanes rig right?
