Custom body lift and zero rates
Discussion in 'The Garage' started by Pvt. Maggot, Mar 1, 2007.
  1. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    Hey guys,
    Insted of paying for a body lift, i'm gonna budget it, and get the machine shop at my tech where my blazer is to make me some aluminum or steel body lift blocks, so I just need some questions answered,
    should I do 1 inch or 2?
    what size bolts will I need
    how many blocks will I need, and will they all need to be the exact same size or do some need to be different?
    now for the zero rates, how long and wide should they be? got a little saggy butt on my 4" lift and I wanna get the back end up a little higher, do they measure out to exactly 1 inch? just need all the specs! thanks alot guys!
    Jack
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    yep, I think the zeros measure out to an inch
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Where is my popcorn smiley:thinking:
    Ira
  4. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    Also, would it be better to use aluminum or steel for the zero rates?
    Much thanks.
    Jack
  5. k2mslskier
    k2mslskier 1/2 ton status
    Feb 18, 2005
    1,524
    Tucson, AZ
    Here ya go.
  6. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    o.k. body lift blocks are all same size. and i would run aluminum for them. and leave the bolt holes a bit on the big side. i had ones i tryed to remove one time and the hole was to tight and with corrosion the bolts set up bad.
    zero rates need to be steel and 1" tall with top sides radiused to help keep springs from cracking.
  7. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    Anyone else? :)
  8. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    since you can't decide between 1 and 2", why not 1.5"?
    i think sweetk30 covered the basics well. X2 on what he said.
    i'd put some antiseize compound on the body mount bolts.
