Custom Chip.
Discussion in 'The Garage' started by grindkings, Jan 11, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    I'm getting ready to send off a request to Jet Performance Chips to have a chip burned. However i just have some question that i need help answering.:
    What is the the stock gear ration and towing weight of a 1991 Blazer?
  2. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    Probably 3.42.
    Towing weight, not sure.
  3. dyeager535
    26,980
    I don't know as I'd go with Jet.
    Check over on thirdgen.org, I believe there have been some very bad issues with jet chips.
  4. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Don't know about the towing weight but I have a 6000 lb package so probably around 6..:confused:
    Just grabbed manual... says 35 lbs of gross weight per 1 hp. Multiply your engines hp by 35 and subtract the weight of the vehicle passengers and luggage.-straight from the manual. don't see a rear end ratio.
    why does the manual say that the 88 350's had 160 hp and 235 ft lbs when most people tell me its 210 with 300 ftlbs. I always saw 210 with 300 ftlbs on all the websites. No way a 4.3L v6 makes 20 less hp and 5 less torque than a 350 on the same year. wtf?
    at the wheels???? still doesn't explain the v6 to v8 numbers.
